quick fuel pump help needed
Old Mar 1, 2008 | 05:29 PM
GMW33's Avatar
Default quick fuel pump help needed
Hey guys, its 60 out here today so i decided to fire the bike up, the battery was dead so i let it charge for a few minutes then fired it up, it went through high idle, warmed to 130degrees and then bogged off and died. went to start it back up, no fuel pump prime. Any help is appreciated while i have this torn apart.. I went back to the black box on the subframe, and all it does is clicks, no fuel prime whine
Old Mar 1, 2008 | 05:38 PM
GMW33's Avatar
Default RE: quick fuel pump help needed
tilted the bike off of the kick stand straight up and the fuel pump primed, Tilt sensor? where is it, what can i do to fix it. After i did that i started it up, then shut it off, and now when i tilt it up again, doesnt make any sound, no click or anything
Old Mar 2, 2008 | 06:35 PM
ReSpEcT's Avatar
Lift your fuel tank. Look to the right side of your air box just behind the fuel rail. Should have a lil black thing with a plug right there. That'll be the TP sensor....=-)
Old Mar 2, 2008 | 06:38 PM
GMW33's Avatar
I messed with some wires up underneath the windscreen yesterday, by the speedo and it started to work, fuel pump primed.. I may have to look further into it to see if a ground came loose or what, but as of now, no problems.. and the salty roads.. = tire breaking loose in first gear
Old Mar 2, 2008 | 06:43 PM
ReSpEcT's Avatar
There is a black wire thats in one of those wiring harness plugs under the front. That black wire goes to your headlight, blinkers, and also the Bank Angle Sensor. IF that wire is jiggles loose it'll make the ECU think the bank angle senor is tripped. This will also keep the fuel pump from priming...Next time it happens...turn the key on and see if the headlights are off or on. If the lights are off and the FP doesnt prime....Then its definately something to do with that wire that goes to the lights and bank angle sensor.....=-)
Old Mar 2, 2008 | 07:45 PM
GMW33's Avatar
the headlights were on the first time it happened, everything worked
NAP2AZ
Jul 25, 2010 12:53 PM
929time
Nov 15, 2007 04:17 PM
