question about tail conversion
Old Apr 2, 2007 | 08:29 PM
ride_002000's Avatar
Default question about tail conversion
I plan on doing the tail and front conversion on my F4. Since no one wants to buy it, I will make an F4i out of it. But my question is for the tail conversion, you know you need the key to unlock the rear to get the seat off. How does that work for the conversion?
Old Apr 2, 2007 | 10:20 PM
Default RE: question about tail conversion
anyone
Old Apr 2, 2007 | 11:14 PM
city worker's Avatar
Sorry I have an F-2, can't help , hate to see you hangin though [&o]
Old Apr 2, 2007 | 11:41 PM
f4i guy's Avatar
The key is located on the back of the rear shovel (piece below the tailight) It uses a cable atatched to a latch mounted on the rear tail section of the frame. I am sure you can modify and use the lock and latch on your f4 (assuming it has one??) so that you can remove the seat to gain access to the trunk. Not sure if this helps?? I just did an undertail on my f4i and had to modify and relocate the key hole to underneath.
Old Apr 3, 2007 | 12:55 AM
I know how it works and everything, I just wanted to know if my existing latch would work. But if anything I will modify it.
Old Apr 3, 2007 | 01:54 AM
thirdgenlxi's Avatar
Ironmang
You can reuse the original lock cylinder, but you have to use the F4i release cable and cable bracket (the piece that holds the lock cylinder in place, and the little screw that holds it down). The cable is shorter on the F4i and it's routed differently, so you need the bracket too
TooBroke0029
Aug 21, 2022 02:10 PM
goatxxmastr
May 30, 2021 08:24 PM
removebeforeflight
May 21, 2012 10:37 AM
Aukai
Mar 17, 2010 03:32 AM
Faerl
Oct 14, 2005 11:34 PM
