Question About Pulling Levers Off.
Old Dec 21, 2011 | 11:38 PM
Incompatible's Avatar
Default Question About Pulling Levers Off.
I was thinking of pulling the levers off to clean and lubricate the pivots as well as the cables. No problems, just slowly working through the bike doing maintenance and learning. Are there any special concerns about the switches or other components when removing the levers? Any special sequence other then removing the pivot screws and going from there? Tks.
Old Dec 22, 2011 | 12:03 AM
74demon's Avatar
Nothing special about them. If your taking them all the way off, you may need to disconnect the clutch cable at the trans if it wont back off far enough at the lever.
Old Dec 23, 2011 | 07:14 PM
Apparently there is something that I don't know about lever removal or I'm being to gentle on the pivot. Removed the cap nut from the clutch lever pivot screw and started to unscrew the pivot. Very hard to turn and once it reached about 4 to 5 full turns it appeared to freeze up. Could not back it out any further and with great difficulty I managed to screw it back in. Has the lever and pivot simply seized (probably never disassembled) and needs a squirt of penetrant or is something else going on? tks
Old Dec 23, 2011 | 07:51 PM
74demon's Avatar
Try lube. It should just unscrew
Old Dec 27, 2011 | 10:26 PM
aurora_F4i's Avatar
Shouldn't need to disconnect the clutch cable from the trans, loosen it up and your good. Just did mine. You can pull on the cable to engage the clutch to give you a little wiggle room. Just adjust as needed with new levers.
Old Dec 28, 2011 | 09:45 AM
Just got a chance to look at an exploded parts diagram, the pivot bolt should come out once the retainer nut has been removed. I'm guessing that something may have scored the bearing surfaces and that's limiting the movement. I'll be a little more "persuasive" when I get home tonight. Thanks
Old Dec 29, 2011 | 04:34 AM
madman's Avatar
Sounds like the end of the screw might have stripped threads if it screws out fine at first but then seizes. If you can get it out use a tap/die on the nut and screw to salvage otherwise get a new one. Could be something else but that screw should come right out pretty easily. Definitely check the sleeve for scoring though and if so replace the lever.
AirmanSkee
Aug 11, 2013 02:15 PM
brenner182
Oct 11, 2010 12:38 PM
akaseman121
Jun 1, 2009 05:51 PM
dashle
Dec 25, 2008 12:04 AM
whizzif
Oct 27, 2005 04:58 PM
