Protect Tank?
Old Dec 1, 2010 | 06:35 PM
Krux's Avatar
Default Protect Tank?
So I am trying to get idea's. My tank is black and shows scratches on the sides of it(were your legs rub). I was thinking of getting a stomp grip to put over it to help protect it. Is there anything cheaper that is like it without paying 40 dollars for? Just getting idea's right now.
Thanks,
Krux
Old Dec 1, 2010 | 07:24 PM
gotcbr's Avatar
There's thin rubber traction sheets that home stores sell for use on wood deck stairs or concrete steps. Cut to the size & shape you want, stick it on, & you're good to go.
Old Dec 1, 2010 | 07:42 PM
Krux's Avatar
Hmm. The only one's I am aware of are either shelving grip sheets(typically there rubber and glue wont hold on to it well) or grip tape sheets for stairs.
Old Dec 1, 2010 | 07:53 PM
redzintimidator's Avatar
Mine Came with a thin clear cover on those areas. Not sure what it was, but it protected very well. I think it was something like the stick on bumper protectors..from like rocks and such.
Old Dec 1, 2010 | 09:51 PM
jp_greenville13's Avatar
You can use vinyl! Get a couple colors and you'll even be able to keep w/e graphics you have. Or a solid color could work to.
Its an idea anyway. Personally I prefer my tank nearly naked
Old Dec 1, 2010 | 09:55 PM
breethwithme's Avatar
do you have a graffics place around you that makes stickers and things there pretty good and well priced
Old Dec 1, 2010 | 11:36 PM
gotcbr's Avatar
Google - "homemade stomp grip" ...you'll get some examples.
Here's a couple of good links...
http://www.centralvalleyriders.com/f...d.php?p=133806
http://www.gixxer.com/forums/showthread.php?t=238629
Walmart used to sell *smooth or diamond-plate design* tacky rubber sheets w/ 3M adhesive on the back. They came 2 per pack for about $8. Harbor Freight used to carry them as well. Simply cut the design you want for your tank & stick on.
Good luck on whatever you decide.
Old Dec 2, 2010 | 07:42 AM
kazspeed's Avatar
Just get some 3m film
Old Dec 3, 2010 | 04:24 PM
Krux's Avatar
Good Idea's guy's. Thanks. My buddy on his zx14 is having the same problem. Its when you wear full leathers it likes to rub on the paint. Were trying to help avoid causing any more paint issues.
Graphics would be a good idea but I have a solid black tank. I should just do grip tape lol. That would be so shady jk
Old Dec 3, 2010 | 05:26 PM
applespeed's Avatar
Try http://www.thetankslapper.com/ for tank paint protectors
x10ded900rr
Dec 10, 2007 09:14 AM
cyber00677
Sep 7, 2007 10:17 PM
Danny74
Jun 13, 2007 07:49 AM
06CBRF4i
Aug 29, 2006 04:22 PM
Black
Jul 26, 2006 11:44 AM
