pros/cons of flushmounts
#21
Yeah, when activated they blink, and when you cancel the signal they just turn off. The ones I got from e-Bay ($20) came with directions, but the install is very basic; self-explanatory. Just don't do the connections half-assed, go to Radio Shack, buy some quality wire connectors and do it right.
I almost forgot, you have to remove the upper cowl/fairing in order to do this. That's actually the hardest part of the project.
#23
Yeah...removing the upper cowl is completely unnecessary. I just took the side fairings off, and loosened the plastic in the wheel well in order to get behind the front cowl. Dont make it harder than it has to be...also, I wouldnt recommend JUST using double sided tape to mount them. Mine came with both double sided tape and a screw/bolt set up to mount them.
#24
#26
