Power Commander III question
Old Jan 20, 2009 | 07:12 PM
KdubyaH's Avatar
June 2011 ROTM
Default Power Commander III question
Which program do you guys recommend I should run from these pre set maps? Im installing the moto gp shorty exhaust when it arrives. Right now I have a Jardine RT-one slip on high mount and everthing else is stock. I dont know what program is on it currently, but id assume its the one for the jardine exhaust
M108-000 Zero Map
M108-001 Completely stock bike 29 KB
M108-002 For use with Erion Racing slip-on exhaust and stock air filter 29 KB
M108-003 For use with Erion Racing full exhaust and stock air filter 29 KB
M108-004 For use with Hindle full exhaust and stock air filter 29 KB
M108-005 For use with Arrow full exhaust and stock air filter 29 KB
M108-006 For use with Hindle slip-on exhaust and stock air filter 29 KB
M108-007 For use with Micron slip-on exhaust and stock air filter 29 KB
M108-008 For use with Yoshimura RS-3 slip-on exhaust and stock air filter 29 KB
M108-009 For use with Akrapovic full exhaust and stock or K&N air filter 29 KB
M108-010 For use with Jardine RT-One slip-on exhaust and stock or K&N air filter 29 KB
M108-011 For use with Jardine RT-One "high mount" slip-on exhaust and stock or K&N air filter 29 KB
M108-012 California Model with Micron slip-on exhaust and stock or K&N air filter 29 KB
M108-013 California Model with Hindle full exhaust and stock or K&N air filter 29 KB
M108-014 California Model with Yoshimura RS3 slip-on exhaust and stock or K&N air filter 29 KB
M108-015 For use with Kerker full exhaust and stock or K&N air filter 29 KB
M108-016 For use with Two Brothers Racing slip-on exhaust and stock or K&N air filter 29 KB
M108-017 For use with Devil High Mount slip-on exhaust and stock or K&N air filter 29 KB
M108-018 For use with Arata full race exhaust and stock or aftermarket air filter 29 KB
M108-019 For use with Micron Serpent full race exhaust and stock or aftermarket air filter 29 KB
M108-020 For use with Remus slip-on exhaust and stock or aftermarket air filter 29
KB M108-021 For use with Micron hi-mount slip-on exhaust and stock or aftermarket air filter 30 KB
M108-501 European Model, Completely stock bike 29 KB
M108-502 European Model with Laser slip-on exhaust (Hot Cam Silencer) and stock air filter 29 KB
M108-503 European Model with Akrapovic full exhaust and stock or K&N air filter 29 KB
M108-504 European Model with Arrow full exhaust and stock or K&N air filter 29 KB
M108-505 European Model with Akrapovic slip-on exhaust and stock or K&N air filter 29 KB
M108-506 European Model with Micron slip-on exhaust and stock or aftermarket air filter 29 KB
M108-507 European Model with Arrow slip-on exhaust and stock or aftermarket air filter 29 KB
M108-508 European Model with G Force slip-on exhaust and stock or aftermarket air filter 29 KB
M108-509 European Model with Scorpion slip-on exhaust and stock or aftermarket air filter 29 KB
M108-510 European Model with Quill T3 road legal slip-on exhaust and stock or aftermarket air filter 29 KB
M108-511 European "German" Model with stock exhaust (catalytic converter), Dynojet O2 Sensor eliminator kit and stock or aftermarket air filter 30 KB M108-512 European "German" Model with Bos ECE approved slip-on exhaust, Dynojet O2 Sensor eliminator kit and stock or aftermarket air filter 30 KB
M108-513 European Model with Renegade high mount slip-on exhaust and stock or aftermarket air filter 29 KB
M108-514 European 2001-2005 CBR600F4i Circui open slip on Stock or aftermarket air filter 29 KB
M108-515 European model-Blue flame slip-on exhaust with baffle, Stock or aftermarket air filter 96 KB
M108-ALL All available CBR600F4i Maps
Old Jan 20, 2009 | 07:18 PM
bwayers's Avatar
Default RE: Power Commander III question
since the moto gp style exhaust has very little back pressure I'd run one of the full system maps
Old Jan 20, 2009 | 07:23 PM
bwayers's Avatar
but after you've ran it for a little while i'd remove your plugs just to see if it's running rich or lean
Old Jan 20, 2009 | 08:51 PM
blackpre93's Avatar
We'll since this topic just came up, i'm not sure what map i'd run becuase i have a muzzy exhaust.
Old Jan 21, 2009 | 01:37 AM
Rock's Avatar
The best way is to have a custom map tuned to your bike like at a shop with a dyno. That would be the most exact way for your bikes current setup, or call Power Commander and ask them their recommendation.
Old Jan 21, 2009 | 05:11 AM
KdubyaH's Avatar
June 2011 ROTM
Ill call up the local shop here and ask em what a dyno run would cost me. If its real expensive ill take a trial an error approach I guess
02cbrguy
Aug 19, 2012 08:43 PM
CodyJ28
Sep 30, 2010 03:00 PM
kallelsf2
Sep 13, 2008 12:33 PM
anthonymartin
Jul 7, 2006 03:57 PM
Truckie973
Jan 10, 2006 09:40 PM
