Possible Tranny Problem
Old Feb 4, 2006 | 06:18 PM
Air4Andy's Avatar
Default Possible Tranny Problem
Hey,
I have noticed a problem that happens occasionally and I was wondering if anyone else has experienced it. This issue only happens when I am really taking off from a stop, damn near full throttle. It also only seems to happen when shifting 2nd to 3rd. And it doesn't happen all the time. Actually rarely, and when I don't expect it, which makes me think that it is my fault. This only happens when I shift without the clutch, too.
...Anyway, what happens is when up-shifting 2nd to 3rd, sometimes it doesn't fully engage in 3rd. It seems like it is stuck inbetween 2nd and 3rd. Since it doesn't catch and I'm cranking on the throttle, the engine revs high like in neutral and it makes a bit of a grinding noise. Does this sound like a problem, or am I just stupid and inattentive and only LAZILY tap it towards 3rd not fully engaging it? I'm just trying to prepare for repair before Spring. Thank you all!
Old Feb 4, 2006 | 09:12 PM
brancart1's Avatar
Default RE: Possible Tranny Problem
yeamy bike does this also, i really hope nothing is going on with it.
Old Feb 4, 2006 | 09:38 PM
Tahoe SC's Avatar
you're hitting a false neutral. usually happens when you don't shift into the gear hard enough but just lazily do it...
Old Feb 4, 2006 | 10:22 PM
chainstretcher's Avatar
Admin Emeritus & MVN
[sm=exactly.gif]
Old Feb 5, 2006 | 12:23 PM
kiggy74's Avatar
I've had this happen as well, but for me it's usually between 4 and 5. This topic has been posted a number of times froma variety of people, so my assumption is that it's a common "feature" of the F4i tranny. I've learned that when I get up around these gears to be very deliberate when shifting, to pull in the clutch all the way, and to pull the shifter very hard.
Old Feb 5, 2006 | 10:46 PM
Tahoe SC's Avatar
yo mang...it'll shift even without clutch...idea is to shift like a mang...and go BAM and BAM and BAM and BAM through all the gears....like a toughass badass mawfaki and not some sissy that goes 'blah' and 'blah' and 'blah' and 'oops, false neutral' ok mang?
do it like bad **** ok? if still jacked, then you gots problems.
T
Old Feb 6, 2006 | 08:24 PM
Air4Andy's Avatar
Cool, as long as it is just my laziness and not a problem. It never happens when I shift aggressively and fully. I'm sure though that doing it to much will grind something in the tranny down to nothing!
nlovern
Jun 7, 2011 02:06 AM
T_roy
Sep 16, 2008 09:15 PM
Heffer2586
May 28, 2008 12:51 AM
jwp6114
Oct 6, 2007 06:13 PM
mongoose2494
Feb 9, 2005 05:09 PM
