plugging tire?
can u plug our tires?
i have a very small nail in my tire causing a slow leak.
i cant ride til i get it fix, obviously, but $$ is kinda slow right now so idk what to do
i was just wondering if you can plug it, its th eback tire.
i doubt u can, it doesnt seem like ud be ableto but i figured id ask just to be sure.
Yes but make sure you use a combination patch-plug from the inside. You will need to take it somewhere to have it done unless you have the equipment to mount and balance bike tires. If you're area shops are like mine and charge min labor of one hour it will cost you 80 bucks or so just to do it, so it's not really worth it unless the tire is like new
Manufacturers recommend against plugging the tire. If I were in your shoes, I'd plug it, but as above make sure it's an inside plug/patch. IIRC those cure over time. Ride slow until you build confidence.
FWIW, I put a plug in the rear tire of my Beemer. 100mph+ no problems.
I have known alot of guys that have used the combe plug patch and they work great. I would just suggest keepin an eye on the tire frequently. You know like your suppose to everytime you get on it like the manual says.
It's up to you, but I had a large hole a new Metz M1 that I plugged with one of those cheap things from the hardware store... worked fine but I decided to be safe and replace the tire a few weeks later. Check out motorcycle-superstore.com for cheap tires, they had M1 rears for like $120 shipped.
