pls help identify this part
Old 08-01-2023 | 11:40 AM
jasonf4i2's Avatar
Default pls help identify this part
2006 F4i
I removed the rear cowl to work on the rear signal lights. When I removed the cowl, a metal piece fell onto the ground. I believe it came from the right (brake) side. I incorrectly assumed at the time it would be easy to "put back" when I was done with working on the lights, but I can't quite figure out where it should go or even what purpose it has. The fact that it is threaded is even more confusing to me since the one bolt I removed on that side to remove the fairing isn't long enough to reach the part. I did recently buy the bike used, so I'm not sure what surprises I'm in store for.
I tried identifying it with the help of the diagrams on partzilla, but was unsuccessful.
Thank you for any help.
Old 08-01-2023 | 11:54 AM
moved to the appropriate sub-forum.
detvil
06-17-2012 10:41 PM
Speedemon636
03-03-2009 10:36 PM
glue
04-25-2007 07:28 PM
Turbinator
03-08-2007 06:42 PM
Quick Reply: pls help identify this part
