Please Help!!
Old May 10, 2012 | 04:49 PM
2oo2CbRF4I13's Avatar
New Member
Talking Please Help!!
Just got my first bike and its running a lil rough. Oil has been changed and now im looking at changing the plugs. I already have NGK laser iridiums on order but was looking for help on the easiest way to change them. If anyone has a good write up that can help me get past taking the tank and airbox off i would appreciate it. Thanks in advance for all the help!
Old May 10, 2012 | 06:59 PM
Matt5606's Avatar
Great video, tells you pretty much everything to do the job. Good luck!
How to do a tune up on a Honda CBR 600 Bullet Bike
Old May 12, 2012 | 01:37 AM
mnguyen84's Avatar
loosen the rear screws of the tank and remove the 2 front ones. lift up the tank and support it. with a screw driver and common sense...disconnect stuff...
Old May 12, 2012 | 10:41 AM
kowen1208's Avatar
My Clymer manual says to remove the radiator from its mounts and push it forward. It is possible to remove them this way (at least if you don't have sausage fingers), but it's very difficult to get enough downward force on the ignition coils to snap them into place. I would have taken the air cleaner box off when I changed mine, but one of the POs apparently thought that if a human can unscrew it, it's not tight enough.
Old May 12, 2012 | 12:05 PM
mnguyen84's Avatar
Like most people, I didn't find it necessary to remove the radiator. if you have beefy fingers like mine, then you can finger coils into place. also it helps if you wiggle them as you apply pressure.
In certain cylinders, I found that it was difficult to pull out the spark plug because of the angle. You may want to use a swivel attachment to my racquet.
