Play in the trottle grip?
How much play is normal in the throttle grip. I am not talking about the grip its self moving i am talking about that play where there is no trottle response? May its just me but I think its getting looser and looser. Any ideas or and I just overthinking it?
Thanks
Thanks
All the ones, including mine, even when new have had about 1/2 inch or of freeplay. It's really personal preference, me I can't stand any freeplay so I have mine tightened up so there's no slack, as soon as you turn the grip you've got throttle response. The looseness was driving me insane!! hahah. Real easy to adjust it with the little adjustment screw right on the cable attached to the clip on
mine also had about half inch pissed me right off especially at low speeds when i went to give it gas it would be all loose then tighten up and usually makes the bike do jerky acceleration.
ORIGINAL: CantBeatRidin600f4i
-Jesse-
I have almost no play in mine. I use a 1/5 turn throttle and don't like to have any slack.
As long as it dosent throttle up when you turn the bars you are OK.
1/2" sounds like WAY too much. I have no idea how you could have good throttle control with that much play.
