Play in the trottle grip?
Old Aug 15, 2006 | 09:57 PM
buckd44's Avatar
Default Play in the trottle grip?
How much play is normal in the throttle grip. I am not talking about the grip its self moving i am talking about that play where there is no trottle response? May its just me but I think its getting looser and looser. Any ideas or and I just overthinking it?
Thanks
Old Aug 16, 2006 | 01:29 AM
thirdgenlxi's Avatar
Ironmang
Default RE: Play in the trottle grip?
All the ones, including mine, even when new have had about 1/2 inch or of freeplay. It's really personal preference, me I can't stand any freeplay so I have mine tightened up so there's no slack, as soon as you turn the grip you've got throttle response. The looseness was driving me insane!! hahah. Real easy to adjust it with the little adjustment screw right on the cable attached to the clip on
Old Aug 16, 2006 | 01:45 AM
five0addict's Avatar
cables stretch, but it may be a sign of damage if it gets real bad.
ajust if you must but always leave some freeplay
Old Aug 16, 2006 | 09:52 AM
CantBeatRidin600f4i's Avatar
mine also had about half inch pissed me right off especially at low speeds when i went to give it gas it would be all loose then tighten up and usually makes the bike do jerky acceleration.
Old Aug 16, 2006 | 09:53 AM
Turnin20s's Avatar
ORIGINAL: CantBeatRidin600f4i
1 I leave about 1/16" of free play so it doesn't want to rev the bike up and it works good for me.
-Jesse-
Old Aug 16, 2006 | 10:04 AM
Blackdog F4i's Avatar
I have almost no play in mine. I use a 1/5 turn throttle and don't like to have any slack.
As long as it dosent throttle up when you turn the bars you are OK.
1/2" sounds like WAY too much. I have no idea how you could have good throttle control with that much play.
Old Aug 16, 2006 | 07:55 PM
buckd44's Avatar
good makes me feel better
Old Aug 17, 2006 | 01:14 AM
rugger19's Avatar
How is this adjusted? Where is the adjustment screw?
Old Aug 17, 2006 | 01:53 PM
You can adjust it at the switch housing or at the throttle bodies.
Old Aug 17, 2006 | 02:23 PM
Ruftags's Avatar
In your manual (if u have it) details how to adjust throttle . Also test in neutral turning bars side to side as Blackdog indicated or your in for a realo bad day.
