Performance Speed Chip
#31
#32
RE: Performance Speed Chip
ORIGINAL: pochop7
thats really good info.. ok now lets say I did what you suggest and put the resistor inline from the sensor for good.....now if your tricking your bike into getting cooler/more dense air as you said.....would it damage the bike if it thought this all the time? I live in florida so summer times get pretty hot...what would be the result if its hot like that and the bike thinks its getting cooler air.....
ORIGINAL: hondapower
I know that I'm extremely new to this board, and haven't even purchased my first bike yet...but felt I can still contribute here quite a bit. I've been a honda-tech member for years now and have been wrenching on cars since I could drive, then got my assoc degree in autmotive tech. Long story short, I've seen these things in many sizes/shapes/names on ebay and honda-tech alike...they do work to an extent, but you can accomplish the same thing with no more than $1 and a trip to your local Radio Shack. Inside that black plastic case is just a pair of resistors, one a little bigger than the other. The **** is a simple selector to select which circuit your IAT sensor will travel on (small resis./big resis./straight thru). These resistors will alter the signal your ECU will get from the Intake Air Temperature sensor and make the bike think its getting colder, denser air...the ECU will compensate for this and add a little more fuel and advance the timing somewhat.
When its all said and done, if you feel comfortable paying $38 for a homemade "chip" that probably has about a 700% markup over the cost of manufacture then buy all means buy it...it will do exactly what its designed to do, trick your ECU. If you're like me however, I would simply lookup the voltage range for the IAT sensor on my bike and buy the correct size resistor from Radio Shack and solder that in-line in the IAT sensor wire with some heatshrink over it and accomplish the same task for about $1. If you're electronically inclined enough (in this case it REALLY wouldn't take much) you could even completely duplicate this product with Radio Shack parts for somewhere between $5-10 and maybe an hour of your time putting it together. Please don't think I'm bashing the seller or the original poster, I'm not at all...just providing some information that I hadn't seen posted yet...hope you guys take this info for what its worth
Oh yeah, I really like the forum and hopefully be picking up my 600 before too much longer. I hope to be around on this board for a while
You needn't worry about causing detrimental damage to the ECU or bike though as long as you make sure everything has a good connection and be sure to seal it with some heatshrink...at most this mod might boost performance enough that you could tell a difference, but it's definately not anywhere close to the tuneability of something like a flash programmer.
#34
All right, I bought one. We'll see...
I probably should have read hondapower's post first, though. Haha. Oh well. I talked to the seller, and he says most bikes see a gain in HP of between 5-7 HP.
Hondapower: I respect your knowledge, and I know that ANY electronic device is generally marked up several times its real value. But, the way I understand what you said is that I would have to buy different resistors and use trial and error to figure out which one works best -- sounds like a lot of work and a lot of time with not too much payoff. Yeah, I'll agree that $40 is way more than $1 or less for a couple of resistors, but its good that I won't have to figure out how and where to hook them up, and then spend the time recording and testing which works best. The seller had already figured that info out, and it seems relatively easy to hook up his product. So at least, even though I'm spending the extra cash, I'm not spending the extra time and labor trying to figure it all out.
Just a thought.
Just a thought.
#36
ORIGINAL: bufferedaspirin
Just a thought.
Just a thought.
#38
#39
#40
ORIGINAL: Jaybird180
I can hardly believe this thread is still going on.
Hondapower, what do you think the engine damage could be with 'a little detonation' from the R&D method you suggest?
Bufferedasprin, I hope you're able to get before/ after dyno runs.
Hope that cleared anything up that you might have questioned. I don't mean to keep bumping this thread back up, but a few ppl were interested in this so I offered what I know on the subject...and until I can give difinitive answers then I'll continue to research this for the previously mentioned posters.
Thanks,
Jon
