PC III :) Now puttering :(
Old Aug 18, 2007 | 12:13 AM
ampfp's Avatar
Default PC III :) Now puttering :(
Installed a PC III this morning... man it's amazing to see those displays turn when you turn the throttle My two gadgets were talking and it was great :P
loaded the standard map for scorpion exhaust. Seemed to make the engine smoother and take out the low-rpm reluctance. Overall good fun on a morning ride
Then changed the oil & filter this evening, lubed the chain... gear shifts are again like butter.Washed the bike clean with cleaner and hosed it with water.
But later took it out for a 20 miles ride or so and it started having these pulsations in the exhaust instead of a smooth rumble... Right when I changed from engine braking to slight acceleration -
while trying to keep constant speed on uneven terrain, at a certain power point while changing between soft acceleration and deceleration.
The puttering/sputtering goes away when I take it to higher rpms (>5k), but if I try to speed up when it's sputtering it seems to really bog down for a second. Once I almost felt the engine shake due to uneven firing.
Could this be the PC III messing things up? I've had some mileage problems and then slight low end power-shortage problems for a while now so I'm inclined to think that the PC III is only precipitating something thats already a problem.
My exhaust also strongly smells of gas while starting the bike... along with some white smoke... this is before and after PC III
Sorry for the long post. I could have probably just said something like 'A cylinder is not firing' but I wanted to give more symptoms...
What to do?
Old Aug 18, 2007 | 12:18 AM
ampfp's Avatar
Default RE: PC III :) Now puttering :(
Oh and the bike is at 15k, I've done the 12k service myself including changing plugs, air filter. I checked valve springs recently (or thought I did - basically opened the airbox, turned the throttle and tried to put pressure on each of the butterflies to see how it opens/closes... seemed as it should be for all)
Thanks guys
Old Aug 18, 2007 | 12:52 AM
ddaren's Avatar
PC's are known to cause some problems to people for some reason. try unplugging the PC and ride the bike around for a while. If problem's gone, yeah it's the PC. e-mail the makers about it, maybe faulty. If problem doesn't go away when you unplug it, then you may be in for a huge bill. You could be having much bigger problems than a faulty PC. Let's hope it's simply the PC.
update us when you find out what happens.
Old Aug 18, 2007 | 09:34 AM
fishfryer527's Avatar
I'd blame the PCIII or you getting something wet. The Honda stuff works, the Honda Stuff always works, that is why I love Honda's. I'd blame the aftermarket stuff or you messing with something Honda did.
edit:
white smoke
Are you losing coolant? White smoke can be a water/coolant thing. Was your oil 'milky' before you changed it? White smoke is never good.
Old Aug 18, 2007 | 11:10 AM
ampfp's Avatar
Coolant level is same as it was months ago. Oil was darkened brown. Although 3.5 quarts came out and 4 went in
Old Aug 18, 2007 | 11:14 PM
PoserX's Avatar
Just try a different map...the slip ons are all pretty much the same.
If that doesn't work it sounds like you may have some engine probs beginning.
If it's an F4i I can send you a kick-*** map. Flip me your email.
B.
Old Aug 18, 2007 | 11:24 PM
TheX's Avatar
ORIGINAL: ddaren
What??? I know a LOT of people that run one, including me and not one person is having a problem with it. Do you have one? What do you base this statement on?
Make sure you have it connected properly and have a GOOD map in it. That means getting it tuned by someone that knows what they're doing. The wrong map will make it run BAD.
Old Aug 19, 2007 | 01:05 AM
DThompson's Avatar
You probably have the wrong map for your bike. That is what is causing your bike to run like crap.
Old Aug 19, 2007 | 04:46 PM
ampfp's Avatar
I have a scorpion slip on so that's the map I downloaded... dyno-tuning will be more $$$
