Out of Curiousity...What is everyones Miles Per Tank??!!
#21
ORIGINAL: KRUSHER F3
Are you sure about that? If so then why is this lable on my 96 F3?
ORIGINAL: white99gt
Our bikes are not designed to run high octane.These are not cars.It doesnt help at all period.
Run regular 87 and be happy.
I have run 87 since day one with zero issues.
Gas mileage varies on riding style,gearing,weight on the bike,tire pressures,etc.
![](http://img.photobucket.com/albums/v630/modGMC/2008_0304Image0001.jpg)
Gasoline pumps typically post octane numbers as an average of two different values. Often you may see the octane rating quoted as (R+M)/2. One value is the research octane number (RON), which is determined with a test engine running at a low speed of 600 rpm. The other value is the motor octane number (MON), which is determined with a test engine running at a higher speed of 900 rpm. If, for example, a gasoline has an RON of 98 and a MON of 90, then the posted octane number would be the average of the two values or 94. High octane gasoline does not outperform regular octane gasoline in preventing engine deposits from forming, in removing them, or in cleaning the engine. Consumers should select the lowest octane grade at which the car's engine runs without knocking. Occasional light knocking or pinging won't harm the engine, and doesn't indicate a need for higher octane. On the other hand, a heavy or persistent knock may result in engine damage.
#22
#24
ORIGINAL: Stephens
I always run the highest octane of 93 whenever I can. I really don't care about saving 20 cents a gallon, it only holds 4.9 gallons.
as far as how many gallons/tank i get, idk yet i just got my bike and havent used a full tank yet but i hope its up there with some of your numbers
#25
#26
ORIGINAL: chpsk8er630
I get 100- 115 till the reserve light comes on then i always fill up. All stock except the exhaust.... dunno y but it runs great.
#29
ORIGINAL: G3NESYS
does having the -1/+2 sprockets get you worse gas mileage?
#30
