Oil weight question???
Old Jan 30, 2009 | 03:40 PM
rauhash's Avatar
Default Oil weight question???
Hello, I just purchased a 2001 f4i with 20,000 miles and I need to change the oil, does anyone have any suggestions which weight and oil I should use with these miles? Thanks.
Old Jan 31, 2009 | 01:14 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Here's the owner's manual: http://www.stephygee.com/2001F4i.zip
...and the Service manual: http://www.carlsalter.com/motorcycle-manuals.asp
You can find the recommended oil(s) inside. Post pics when you get a chance & maybe introduce yourself
Old Jan 31, 2009 | 01:46 PM
alloutf4i's Avatar
10w40 is what I use in my 03 and the 01 is the same.
Old Jan 31, 2009 | 11:14 PM
white99gt's Avatar
i use 10w40 and change it every 4k miles(but thats me).
Old Feb 1, 2009 | 12:08 AM
NasTraDooMis's Avatar
Question
Do you use regular auto oil or atv 4 cycle oil ? or does it really matter ?
Old Feb 1, 2009 | 12:55 AM
Incognito's Avatar
If you use motorcycle oil, it has to be four-stroke motorcycle oil. You can find those at local auto part stores. They'll usually be up in the corner, and will typically have a little motorcycle on the label.
Some people use automobile oil, but you have to know which type to use or you can cause transmission problems with your clutch.
As far as synthetic versus mineral oils, synthetics generally last longer and imo are better all around. Nonetheless, with current oil technology the way it is, you can't go wrong with either. Synthetics, simply put, cost more money.
The main thing with engine oil, and more importantly than brand, is to stick to regimented regularly scheduled oil changes.
Here's a couple of links regarding this subject:
http://motorcycleinfo.calsci.com/Oils1.html
http://vfrworld.com/tex_vfr/tech/oil.htm
Old Mar 25, 2009 | 07:24 AM
graf4's Avatar
How many quarts are recommended?
Old Mar 25, 2009 | 08:22 AM
some guy #2's Avatar
roughly 3.5 (with filter change)
Get the bike level, put in 3 bottles and start checking the fill level as you pour the 4th in.
Old Mar 25, 2009 | 08:40 AM
graf4's Avatar
Is the level supposed to be filled half way?
Old Mar 25, 2009 | 08:48 AM
Berto's Avatar
With the filter, the volume is 3.7 litres. I use shell Rotella myself, a diesel engine oil that meets all the called-out SAE requirements. It's cheap and comes in 4.0 litre jugs.
Dump the new oil in, use the old container for the waste.
--Paul
