Oil crush washer - where to buy?
I have an oil leak, it leaks 1 drop a day and it started after my oil change.
I did not replace the crush washer.
I wiped it dry a few times and made sure nothing else is cracked and am 100% sure its the crush washer.
Can I buy one at O'reillys or at Autozone or Advance Auto Parts?
If yes, what is it called?
Do I ask for a 12mm crush washer or what?
I get mine from the Dealership but thats just because it is beside my work.
I'm sure they would understand what your talking about if you asked for a 12mm crush washer for your oil drain plug.
I bought a couple 12mm copper crush washers from O'Reilly last week when I changed my oil. They seemed a little big, so when I tightened down the drain bolt I made sure the washer was centered before I gave it that final crank. I've put on about 100+ miles or so since the oil change and some of those were on the Dyno, still no leak yet.
Moses
Moses
I got the 12mm copper washers from O'reilly.
The washers have a flat side and a curved side.
Someone told me mybe I put on the washer incorrectly thats why I got the slow leak.
Which side goes towards the oil pan?
The whole point of a crush washer is that it MUST BE ALUMINUM! Thus it can "crush" and seat correctly upon torquing down...if you just went and bought a regular old 12mm washer then dont wonder why you are leaking oil...oh and dont trust muppets at auto stores..
Flat side towards pan
After running a quick search it seems as though a lot of people use copper washers for oil drain plugs on cars and bikes. I think either copper or aluminium should work.
