Oil crush washer - where to buy?
I have an oil leak, it leaks 1 drop a day and it started after my oil change.
I did not replace the crush washer. I wiped it dry a few times and made sure nothing else is cracked and am 100% sure its the crush washer. Can I buy one at O'reillys or at Autozone or Advance Auto Parts? If yes, what is it called? Do I ask for a 12mm crush washer or what? |
I got mine at the local honda dealer, I think it was $.50 or less.
I get mine from the Dealership but thats just because it is beside my work.
I'm sure they would understand what your talking about if you asked for a 12mm crush washer for your oil drain plug. |
I bought a couple 12mm copper crush washers from O'Reilly last week when I changed my oil. They seemed a little big, so when I tightened down the drain bolt I made sure the washer was centered before I gave it that final crank. I've put on about 100+ miles or so since the oil change and some of those were on the Dyno, still no leak yet.
Moses |
Thanks everyone, there's an O'reillys near my work, will check them out today.
Any autoparts store should carry them. Just ask for a 12mm crush washer and tell them what it's for if they are confused.
I got the 12mm copper washers from O'reilly.
The washers have a flat side and a curved side. Someone told me mybe I put on the washer incorrectly thats why I got the slow leak. Which side goes towards the oil pan? |
The whole point of a crush washer is that it MUST BE ALUMINUM! Thus it can "crush" and seat correctly upon torquing down...if you just went and bought a regular old 12mm washer then dont wonder why you are leaking oil...oh and dont trust muppets at auto stores..
Flat side towards pan |
Originally Posted by 600F4inoober
(Post 1065737)
Has anyone tried one of those quick-drain type plugs where you flip a lever or push and turn to drain the oil without actually taking the plug off?
Like these. I saw one the other day at the autoparts store and thought it might help make oil changes a little easier. |
