Oil change and problems
Old Jul 28, 2008 | 06:45 PM
Twiztid CBR's Avatar
Default Oil change and problems
ever since i put synthetic oil in my bike i have has issues with my bike not starting and when I turn it off it doesn't want to start again?
Old Jul 28, 2008 | 07:06 PM
fishfryer527's Avatar
Default RE: Oil change and problems
It's not the oil.
Maybe something wacky in a high mileage worn out gunked up motor could happen when the synthetic degunks it, but I would assume the problems are coincidental. The motor isn't using alot of oil now, is it? Any blue smoke? Did you look at the plugs?
Old Jul 28, 2008 | 10:19 PM
WOT's Avatar
WOT
I guess the only thing that could be caused by an oil change is overfilling... If you didn't do that, I would rule out the oil change and figure it's something else that just happened at this time.
Old Jul 29, 2008 | 03:25 AM
kukku's Avatar
If you had to almost totally open the throttle beforehitting the starter button and keep it open when pushing it, does it start better? Mine runs slightly rich anddoesn't always start when turning it off andimmediately try to restart it.
Old Jul 29, 2008 | 07:56 AM
Jaybird180's Avatar
If you think the oil is the problem try starting it without it.
j/k
Check your wiring. Put your ECM into diagnostic mode and check the codes. Some car engines won't start if the sensors detect an anomaly. I'd bet you jiggled something loose and it's causing a fault.
Old Jul 29, 2008 | 07:30 PM
fishfryer527It's not using any oil and there is no blue somke that I see I haven't looked at the plugs yet. I didn't change the oil last time my loacl shop did it and Im taking it back there to complian the bike ran fine before I took it in for a oil change
Old Jul 29, 2008 | 09:10 PM
how about gas mileage? worse? maybe some fuel regulator type doohicky is dumping a little too much fuel and almost causing a flooding condition?
Just guesing here, but maybe with enough questions it'll help diagnose it.
Old Jul 30, 2008 | 02:04 AM
FLYOU's Avatar
1) drain oil
2) replace with bleach to clean out gunk
3) run bike
4) drain bleach
5) replace with oil
problem solved
Old Jul 30, 2008 | 02:07 AM
FLYOU's Avatar
but seriously, any weird indications? FI light staying on/flashing? when i gave my bike her first oil change, i caused an electrical nightmare and i couldn't get my bike to start for days!
yeah, none of those lights should be on at the same time...
Old Jul 30, 2008 | 08:52 AM
WOT's Avatar
WOT
ORIGINAL: FLYOU
1) drain oil
3) run bike
4) drain bleach
5) replace with oil
problem solved
You might want to follow this up with JUST JOKING, before someone does this.
