On/Off throttle clunk
Old Mar 11, 2021 | 12:46 PM
Scott91370's Avatar
Default On/Off throttle clunk
Not sure when it started but my bike has developed a clunk when I let off the throttle and again when get back on the throttle - every time. Closest I can explain it is if a truck has a bad u-joint and you get on/off throttle and it has to take up the slack.
I haven't started digging in yet but the chain and sprockets are only a couple thousand miles old but everything else has about 18k miles.
Any thoughts from the collective geniuses?
Old Mar 11, 2021 | 01:10 PM
I would be starting with the chain, if it is a bit loose you can get that feeling. Then onto sprockets cush drive etc, although should not be an issues on that mileage.
What bike is it?
Old Mar 11, 2021 | 02:22 PM
Scott91370's Avatar
I was thinking cush drive just because that is the only original piece but since I haven't been able to actually look at it there is no telling.
It's a 2002 F4i.
Old Mar 11, 2021 | 02:25 PM
Your description certainly sounds like drive train related and chain and sprockets fit the bill to a T. A close examination of that would be first on my list of things to check.
Old Mar 11, 2021 | 02:28 PM
Scott91370's Avatar
I'll get it up on a stand when I get back from vacation (not riding it on vacation) and inspect the drive line from front to back.
Thanks!!
Old Mar 12, 2021 | 06:36 AM
chris0986's Avatar
My guess would go in four ways:
- the rubber sprocket inserts are gone
- The rear wheel bearings, but that would probably go in combination with riding noise.
- The rear wheel bridge (or whatever it is called in english) bearings have play.
- The front steer bearings have play.
Good luck and let us know.
Old Mar 13, 2021 | 07:59 AM
Doc Samson's Avatar
It's a 2002 F4i.
My thought as well... and easiest to check and/or replace!
Old Mar 23, 2021 | 07:11 PM
Scott91370's Avatar
It appears it is something with the cush drive. Almost like it is totally gone. I put it on the stand and in gear. Starting to move the wheel figuring it would have a little play...yeah - I measured how far the letters on the tire moved. 7 full inches! At this point I thought that maybe I put it in the wrong way but that is an awful lot of movement since each section is like an inch wide.
I haven't torn it down yet because I might actually need it tomorrow for transportation. I will post more as soon as I get it apart.
Old Mar 23, 2021 | 07:50 PM
Scott91370's Avatar
Took the wheel of and sure enough not one piece of rubber where the cush drive goes. Almost like I lost it.
Old Mar 23, 2021 | 07:54 PM
Doc Samson's Avatar
Just be real easy on the clutch!
