On/Off throttle clunk
Not sure when it started but my bike has developed a clunk when I let off the throttle and again when get back on the throttle - every time. Closest I can explain it is if a truck has a bad u-joint and you get on/off throttle and it has to take up the slack.
I haven't started digging in yet but the chain and sprockets are only a couple thousand miles old but everything else has about 18k miles.
Any thoughts from the collective geniuses?
My guess would go in four ways:
- the rubber sprocket inserts are gone
- The rear wheel bearings, but that would probably go in combination with riding noise.
- The rear wheel bridge (or whatever it is called in english) bearings have play.
- The front steer bearings have play.
Good luck and let us know.
My thought as well... and easiest to check and/or replace!
It appears it is something with the cush drive. Almost like it is totally gone. I put it on the stand and in gear. Starting to move the wheel figuring it would have a little play...yeah - I measured how far the letters on the tire moved. 7 full inches! At this point I thought that maybe I put it in the wrong way but that is an awful lot of movement since each section is like an inch wide.
I haven't torn it down yet because I might actually need it tomorrow for transportation. I will post more as soon as I get it apart.
