OEM Key blanks?
Old Jul 31, 2013 | 10:10 AM
MattSD's Avatar
Default OEM Key blanks?
Hi guys. Does anybody have a source for oem blank keys for an 03 f4i? Can they be cut easily or am I going to have a hard time finding someone/ somewhere that can duplicate the original?
I was given an OEM blank with the bike but it's gone missing so I'd like to get another and get it cut.. and not lose it.
Ps. I did google this and couldn't figure out if I actually do need the key code or not if I have an original that can be copied. Some people are saying the code is on the bike either around the ignition or near the tail lock or under the gas tank but I can't find any definitive answers.
Old Jul 31, 2013 | 11:53 AM
Raoufhakam's Avatar
you can buy a cheapo key blank from eBay for $1.50 and it will work fine (i have one and been using it for almost a year now)
your best bet to get it cut is any local locksmith that will actually do it the old way, if u go to Walmart, CanadianTire or Sears their new cutters wont do it cause they dont have a die for it.
Old Jul 31, 2013 | 12:04 PM
74demon's Avatar
A locksmith will have the right blanks and cut them fairly cheap. Their blanks are decent quality, but are not OEM. If you want OEM, order them from the dealer and have them cut. Beware of OEM imitations that are really poor quality that you find online.
Old Jul 31, 2013 | 01:49 PM
coalminer frank's Avatar
I got the ebay blanks, took them to Ace Hardware, he cut it for less than a dollar. It worked sometimes. I used my dremel to make it a little more define. It works better now. Oh, its for an 06 cbr 600rr.
Old Jul 31, 2013 | 06:06 PM
bigboi18184's Avatar
Have ordered them from ebay over seas sellers, bikebandit, and the Honda Dealer and they all were of the same quality. Only places I have found that would cut them are locksmiths and it's under 2$ per key here.
Old Jul 31, 2013 | 09:41 PM
raylee's Avatar
The only thing with OEM is that they have a copper core, I think.. well, they aren't steel all the way through in any case. Some places can't cut the keys properly because of that. Like the above have stated, any decent locksmith or key cutter can copy it. You only need the key code if you've lost all keys.
BTW, take it easy with imitations, I've seen plenty of them snap in the fuel cap.
Old Aug 1, 2013 | 12:46 AM
MattSD's Avatar
Thanks for the replies guys very helpful!!
My existing key doesn't work very well in the gas tank. I kind of have to fiddle with it to get it open. I'm wondering if maybe I should just try to order one based on the code, maybe the one I have is really worn and won't make a great template for a copy? If that's the case, how do I go about locating the code for the key?
Thanks again.
Old Aug 1, 2013 | 07:24 PM
raylee's Avatar
It's kind of a pain because the bolts holding in the ignition cylinder are one-way bolts designed to deter theft. Anyways, I've seen people manage with a regular allen head and a lot of muscle or drilling them out. They're located from underneath and it's easiest to just take off the top triple or bridge and flip it upside down. Once you have the ignition cylinder removed you'll see a 3-6 digit alpha numeric code like 6ga blah blah or something like that engraved on the side. Oh yeah, there's a wiring harness coming from it, but you just have to unclip it.
drunkinmist
Jan 21, 2013 11:45 PM
skubysnak
Apr 14, 2008 11:58 AM
rba007
Mar 6, 2006 08:47 PM
