Octane
Old Sep 13, 2006 | 12:08 AM
markobenin's Avatar
Default RE: Octane
ORIGINAL: vinny7
The highest we can get in Cali is 91 its only about 20 cents more that 87 so what the hell when your just getting 4 or 5 gallons.
Amen brotha!
Old Sep 13, 2006 | 11:46 AM
Blackdog F4i's Avatar
Default RE: Octane
I guess I am just a fan of using what the bike was designed for.
You know HONDA probably knew what they were doing when they built it.
It would be different if you had a really high mileage bike that was pinging with low octane, or if you were running nitrous or turbo.
Old Sep 13, 2006 | 04:57 PM
Jaybird180's Avatar
Default RE: Octane
Some buddies said they noticed black smoke coming out the pipe w. 87. I noticed snappier low-mid response w. higher octane. I'm currently NOT using a custom map but would like to. The bike runs cooler w. lower octanes.
Old Sep 13, 2006 | 05:59 PM
discohouse's Avatar
Default RE: Octane
I get better milage with 87 than higher octane. Think it's related to the bike actually using all the fuel b/c 87 doesn't require as much compression. Why use higher octane- all it does is stop knocking and 87 doesn't make my bike knock. How about yours? My car specifially calls out for it (92+), the bike doesn't.
Old Sep 13, 2006 | 06:04 PM
ninetyfivehp's Avatar
Default RE: Octane
87 octance is gonna provide the most efficient and complete combustion on the F4i, which in turn will give a tad more HP and MPG.
Old Sep 13, 2006 | 07:23 PM
unrealtrip's Avatar
Default RE: Octane
ORIGINAL: vinny7
Actually you can get 110 near Sear's point at a regular station and right down by my place there's a pump with 100.
Old Sep 13, 2006 | 08:37 PM
IDL's Avatar
IDL
Default RE: Octane
Yikes, searching around the net on this topic just pulls up hoards of forums with people arguing about what is better.
Does the manual say 87 *or higher*?
I'm definately going to reduce the octane from 94 like I was putting in before, but there isn't any definitive answer on what is the best. The differences between 87 and say, 89 are probably insignificant
Old Sep 13, 2006 | 08:57 PM
unrealtrip's Avatar
Default RE: Octane
The definitive answer is simple: The lowest octane that does not cause the engine to ping is the best for *that* engine.
Old Sep 13, 2006 | 11:09 PM
Phi's Avatar
Phi
Default RE: Octane
hmmm . . . so i should stop putting 93-94 octane into my gas tank and start putting 87 octane into my tank?
Old Sep 14, 2006 | 12:21 PM
Default RE: Octane
YES!!!
Unless you get pinging. Make sure you use good gas too, and don't fill up if you see the tanker truck there.
