Not Your every day Problem....
Old Feb 3, 2009 | 03:20 PM
maximus3's Avatar
Default Not Your every day Problem....
I was gonna install frame sliders on my f4i and when I went to un screw the left side motor mout bolt and it broke off on me and now stuck in there. In the process i felt it going a little tight so i was doing it slow but then it snapped. I dont know if the previous owner messed with it and and knocked off the thread. Any one has any suggestions? I really dont wanna take it to Stealership to get it fixed.
Old Feb 3, 2009 | 03:48 PM
Aken's Avatar
July 2008 ROTM
Dremel a line into it and use a flat head screwdriver to remove?
Old Feb 3, 2009 | 07:00 PM
maximus3's Avatar
i know what u saying but i can even get in there with a dremel, it broke off in the frame
Old Feb 3, 2009 | 07:13 PM
bwayers's Avatar
get a drill with a bit a little smaller than the bolt and drill down through its center
then take a left hand thread bit that's almost as big as the bolt and run it out
Old Feb 3, 2009 | 08:46 PM
maximus3's Avatar
whats the left hand thread bit? Im not really familiar with those just know basic
Old Feb 4, 2009 | 01:56 AM
kukku's Avatar
Take it to a shop then, you wouldn't want to start learning / experimenting on your bike.
Old Feb 4, 2009 | 08:31 AM
alloutf4i's Avatar
Go to an auto parts place or something similar and tell them your problem. They will know what you will need and how to do it. Basically you drill a small hole in the bolt and use the left handed thread bit (the teeth go in the opposite direction) to pull the bolt out. It is pretty easy
Old Feb 4, 2009 | 10:31 AM
agent orange's Avatar
Sounds like the bolt was cross threaded at one time. No fun, i had the same thing happen to me.. took a small drill bit drilled down into the center of the broken bolt.. Used and easy out and just backed it out.. Your probably going to have to drill out the threads and re tap the hole once you get the bolt out.. At least that's what i had to do, not that hard just needed to use a little bit bigger bolt.
Old Feb 4, 2009 | 10:37 AM
oh yeah in case you don't know what an easy out is.. it looks like a drill bit but it doesnt cut..
Old Feb 4, 2009 | 12:37 PM
dans03f4i's Avatar
Sounds like someone forced it into the case when it wasn't in the threads right, leading you to strip it when you took it out.
