Not saving my trip or time on gauge
Old Dec 12, 2012 | 07:39 PM
02 ratrider's Avatar
Default Not saving my trip or time on gauge
02 f4i
was just wondering if the gauges are spose to save the time and trip? Cause its not lol im 80 percent sure it is saveing the milage (i was riding in 27degrees out i ran for the heat lol)
so was just wondering if this issue is common or if its just the bike??
thx u
Old Dec 12, 2012 | 07:46 PM
gotcbr's Avatar
Originally Posted by 02 ratrider
02 f4i
was just wondering if the gauges are spose to save the time and trip? Cause its not lol im 80 percent sure it is saving the mileage...
so was just wondering if this issue is common or if its just the bike??...
Of course its supposed to save 'em. ;-) Check you wiring connections/plugs. Also, if you're so inclined, check & clean the pins on the back of the gauges. Otherwise, you'll have to get used to the way it is.
Old Dec 12, 2012 | 10:23 PM
stlcbr600f4_newb's Avatar
what that sounds like is your losing power to the cluster is after you turn the key off. i would get a meter out and test for voltage on the red/green wire on the i think the black 9p connector..... sound like you might not have constant power to the cluster check the ground to it could be loose.....
primary ground at the starter see if it moves otherwise it's hard to get to..
check the ground near the radiator and the ground under the tank and seat area....
normally have constant power then receive main power when you turn the key...
i think you are only getting the main power.... good luck
that is on top of what gotcbr said...
wiring diagram in service manual will help a great amount
Old Dec 13, 2012 | 02:36 PM
for the 2 plugs one is temp,speed,ign,illum+,bat+,f1nd-(cant read it) and tacho the other one is oil-,turn r+,Hi beam+,neutral-,turn L+, (.), sensor-,res sensor, and side stand,
i think the 2nd group of wires is the black plug but the ? is which wire is for memorey which is not stated
Old Dec 13, 2012 | 03:43 PM
i traced the one bat+ wire to a fuse and there found my "clock"(labled on the fuse box" fuse missing i spliced it with a wire and my clock turned on and my tach went through a cycle my next ? is does the clock stay on with the key of its now saving the time when turned off and on but is now staying on...is this normal?
Old Dec 13, 2012 | 03:52 PM
gotcbr's Avatar
When wired correctly, the clock will save the time as long as the battery is alive.
Old Dec 13, 2012 | 06:43 PM
Neonfire's Avatar
I have an 02 F4i and my clock remains on even with the key out of the ignition. That is normal so just check your mileage and trip and you may have solved your problem!
Old Dec 13, 2012 | 07:07 PM
sweet thxs everyone sry for being a noob lol like i said the newest bike ive owned is a 78 gs550 lol
Old Dec 13, 2012 | 07:18 PM
gotcbr's Avatar
No prob at all. Everyone was new at some point. ;-) Ask anything you need.
Kevwa451
Jul 21, 2011 03:38 PM
abs929cbrrr
Sep 13, 2008 11:37 AM
HondaRocks
Sep 12, 2008 04:13 AM
jjsmi
Mar 16, 2008 12:45 AM
airick
Apr 24, 2007 09:15 PM
