Life threatening or time saving?
Old Jul 16, 2011 | 04:49 PM
Kevwa451's Avatar
Default Life threatening or time saving?
It's time for a chain and sprocket change on the bike. Chain loses tension after about every 200 miles and is in the red zone, there's also a very tight spot. Thing never got taken care of by the PO but as for my question if I get a Regina kit is it alright if I just use the clip masterlink instead of the rivet style? And can you take off the clip masterlink and re-install it whenever you want? Thought I read that somewhere on here but I'm a big fan on soaking the chain in kerosene every now and then for a deep cleaning. Thanks for any advice you can give.
Old Jul 16, 2011 | 04:54 PM
rjgraves84's Avatar
Your gonna get all kinds of feedback on this one, I've used both and still use both and have never had a problem.
Old Jul 16, 2011 | 05:03 PM
Kuroshio's Avatar
https://cbrforum.com/forum/cbr-600f4...riding-121469/
Old Jul 16, 2011 | 05:30 PM
Kevwa451's Avatar
I wonder if that had anything to do with him riding with extra weight. I know either way it shouldn't happen but it still makes me wonder.
Old Jul 16, 2011 | 05:42 PM
Kuroshio's Avatar
Sounds like the beginning of a rationalization to me. "extra weight may have..." -> "I don't carry passengers" -> "I'll be fine".
Old Jul 16, 2011 | 07:14 PM
Sprock's Avatar
Rivet the darned chain there's other things more important to be looking out for
with your bike than worrying about a chain coming apart.
You'll never catch me using a clip especially when the chain gets older with many miles
Old Jul 16, 2011 | 07:35 PM
segraves1's Avatar
Not worth the risk. Chains and tools are cheap, skin is not.....
Old Jul 16, 2011 | 08:46 PM
herbcbr1000f's Avatar
i say rivet i have had to many experiences where the clip would pop off and i would be stuck with out a chain also it can damage your case seen that alot too
Old Jul 17, 2011 | 12:37 AM
tyfrist's Avatar
the rivet tool is 70 bucks online. or even cheaper at other sites. how much is your life worth?
you don't need to soak the chain in kerosene, just get a grunge brush and a good chain cleaner and brake parts cleaner and you'll be good to go
Old Jul 17, 2011 | 02:00 AM
RedBaron's Avatar
Definitely rivet it, I've lost about 5/6 clips on my current chain and it gets annoying having to check if its still on. But putting a slight bend in the clip helps if you must use them.
