No headlight
Old Jan 12, 2009 | 10:36 PM
stick1300@yahoo.com's Avatar
Default No headlight
I was riding back to my dorm the other day and noticed my high beam light wasnt on even though my lights were switched to high. I leaned out over the front and, sure enough, I didn't have any lights. I've got an Acerbis Cyclops and they went out once over the summer and it turned out to only be a blown fuse, no biggie. I put a higher wattage bulb in a few months ago, if that matters. I've checked my fuses and where I wired it up and everything looks good, so why dont I have any lights!?!
Old Jan 12, 2009 | 11:40 PM
MrBomb's Avatar
Default RE: No headlight
not sure if the f4i is the same with the f3, but mine went out and i traced it back to a solder connection came loose on the start switch
Old Jan 13, 2009 | 10:32 AM
Hopefully I'll be able to really look everything over later and come back with more info...
Old Jan 13, 2009 | 10:34 AM
D2VW14_20's Avatar
That could be anything from a loose connection to a blown bulb. Check all your connection points. Soldering or male,female connectors are the way to go!
Old Jan 13, 2009 | 01:03 PM
Yeah, I'm going to check my wiring more. I doubt its a bulb though, cause why would one blown bulb knock out my entire headlight?
Old Jan 13, 2009 | 06:04 PM
ampfp's Avatar
your starter switch might be sticking. try pulling it out after you start the bike.
Old Jan 13, 2009 | 06:24 PM
stick1300's Avatar
Haha, I wish it were that simple. My starter has been sticking since I got the bike (and it did on my old F4i too) so I'm used to that. I ended up dropping it off at my friends dads cycle shop. He's cool enough to hook me up with cheap/free labor when I need it, plus business is pretty slow right now so he could get me in asap.
cmartino88
Aug 1, 2012 06:39 AM
papa wheelie
Jul 20, 2011 11:16 AM
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
