New flush mounts = electrical has gone crazy
Old 08-19-2012 | 12:50 AM
boredandstroked's Avatar
Default New flush mounts = electrical has gone crazy
I bought some yana shiki flush mounts from motosport.com on closeout figuring what the heck, their cheap so lets try em. My old mototek flush mounts weren't working anymore anyways. The oem wiring for front turn signals is 3 wires: a ground, a flasher and a running wire. The new flush mounts only have a red and black wire and no instructions. So I wired the red to the running and flasher wires for the bike and black to the ground. The flush mounts work great with this setup, problem is my taillight [aftermarket intigrated] is now yellow instead of red and the turn signal is red instead of yellow. Also my turn signal arrows on my dash are always on now and blink brighter when I use my signals.
Im going to try just wiring up the turn signal and not the blinker wire to the flush mounts and see what happens. Any ideas on whats going on?
Old 08-19-2012 | 03:05 AM
estate4life's Avatar
February 2012 ROTM
Your not suppose to wire the running and flasher together to the red...it's shorts everything. You gotta convert the 3 wires to 2 wires using diodes...if you wants running lights. Are the new signals led?
Old 08-19-2012 | 03:50 AM
Yes they are. Very bright ones.
Old 08-19-2012 | 08:47 AM
February 2012 ROTM
If led, then you can do it (running lights) because led won't get too hot and melt your fairings. There was a write up here some where regarding convert 3 wire to 2 wire set up using diodes....those diodes cost less than a $1. May be some members here can help find this thread...I'm currently on my iPhone so cannot search site so easily.
Old 08-19-2012 | 08:52 AM
h0ndafanat1c's Avatar
I would say just convert from 3 to 2 wires and call it a day. Just don't wire the running light...it Should be the one that is two colored.
p8ntballn2
03-05-2010 07:55 PM
04cbr
08-07-2006 04:54 AM
gman
08-03-2006 07:57 PM
gman
08-02-2006 09:45 PM
Da CbR KiD
03-20-2006 09:01 PM
