Need to know? rear shock
Old 05-16-2012 | 08:03 PM
mass-cbrf4i's Avatar
Default Need to know? rear shock
i need to know where do dial the rear shock to is there a mark that i line the number too is what i need to know? help please ....thanks
Old 05-16-2012 | 08:58 PM
zimdbw74's Avatar
There are a few different adjustments you can make to the rear. For Rebound and compression the stock setting is 1 1/2 turns from fully turned in. As far as the spanner nut at the bottom of the spring the standard position is #3. This one goes from 1-7
There are two raised notches viewable from either the left or right side of the bike the number that its set to will be directly above these notches. So for example in this picture the setting is on 5.
Hope this helps.
Old 05-16-2012 | 10:06 PM
thanks so much thats exactly what i need to know .......lock this up please
Old 05-16-2012 | 10:12 PM
boredandstroked's Avatar
If your going to adjust the suspension then why wouldn't you actually set it instead of putting it to stock settings?
Old 05-16-2012 | 10:21 PM
zimdbw74's Avatar
I was just giving stock settings as a base line for him to go off of. I figure if you know where to start you're better able to fine tone, either softer or harder.
In reality I guess it was more information then needed since the question was really just about the notches.
Old 05-17-2012 | 05:43 AM
That was not to much info cause with me being a newbie to motorcycles u probably just answered a question to be asked in the future......thanks again
Old 05-17-2012 | 12:31 PM
CaBeR6's Avatar
U agree about preventing further questions and while on subject might as well cover everything about it
Old 05-19-2012 | 04:03 PM
InlandEmpireRider's Avatar
Thanks for posting up!
Can someone help clarify for me?
Clockwise on the compression makes the shock HARDER to compress.
Clockwise on the rebound makes the shock rebound SLOWER.
Higher number on the spanner (preload) makes the bike sag LESS with the same rider.
Do I have that right?
Thanks in advance!
Old 05-21-2012 | 08:24 PM
going off your picture i had to adjust by lining the number to the adjustment screw, cause i cant find the dot stamped .on mines there's a lot of oxidation.but i noticed in the picture above that the tab is pointing up where on mines its in a different direction.so on a nice day im going to try to clean it up and see exactly where the dot is located.
Old 05-22-2012 | 10:56 AM
zimdbw74's Avatar
If you can't see the dimple it's no big deal. If you look at the shock you should notice that there are two raised nubs one on each side, they are oval shaped. It's these raised nubs that the adjustment notches click over to. So even if you can't find the stamped dot it's no biggie.
robertjhunt
06-23-2010 07:01 PM
Noam
05-22-2008 01:15 PM
