need help on changing rear pads !!!!
Old Dec 1, 2008 | 10:41 PM
playb0i's Avatar
Default need help on changing rear pads !!!!
is there another way to NOT to take the exhaust off to change the rear pads??? thanks.
Old Dec 2, 2008 | 12:00 AM
PlayfulGod's Avatar
Default RE: need help on changing rear pads !!!!
I've never took the exhaust off to change the rear brakes. I just take a large screwdriver n use to to force the caliper piston back. Then I remove the rear retaining pin and then rotate the caliper forward, up off the rotor. The remove the remaining pin holding the pads in, and then clean everything up and install the new pads.
Old Dec 2, 2008 | 07:08 AM
MC_spirited's Avatar
The exhaust takes one minute to take off, and it allows you to clean the rear tire much easily. It took me less than ten minutes to take off the front fairing. This isnt all that difficult. If you havnt changed the fluid or pads or dont know how old the fluid is, flush out the brakes. Take off the caliper, use a screwdriver or a large C clamp if you need it to push the pistons back.
Old Dec 3, 2008 | 01:19 PM
ampfp's Avatar
no need to mess with the exhaust. just get around it
Old Dec 3, 2008 | 07:10 PM
LiMe_GrEeN_MaChInE's Avatar
+1 to the cleaning always a good thing to clean up the dirty parts man, one minute of work compared to turning 10 heads that night ya know
alysiak00
May 18, 2010 01:58 PM
Griffin
Oct 16, 2007 06:09 PM
sstgonzo
Aug 17, 2007 01:09 AM
bluestanger66
May 12, 2007 04:17 PM
fading@verizon.net
Oct 17, 2006 07:39 PM
