need help asap
Old Jan 29, 2012 | 02:37 PM
TeamAeD1's Avatar
Default need help asap
so whats the minimum cca for a aftermarket battery for an f4i. help please and thanks
Old Jan 29, 2012 | 10:45 PM
boredandstroked's Avatar
I highly doubt anyone has tested smaller and smaller batterys to see what the smallest they can use is. Most people want as much power as they can get. As such my answer is whatever the stock battery is rated at.
Old Jan 30, 2012 | 05:43 AM
jveach's Avatar
I know the 50 dollar battery from walmart works just great. If your looking for a cheap battery.
Old Jan 30, 2012 | 06:25 AM
jeffjones's Avatar
A battery is something you probably don't want to get the minimum for.
As mentioned you can get the for cheap if you shop around.
Old Feb 1, 2012 | 11:42 PM
TeamAeD1's Avatar
thanks guys. yeah i took that 50 cca gel back and just ended up trickling my old one and it works fine. i was only wanting a smaller because all my components are pretty tight. and useful info is the f4i draws anywhere from 75 cca to 100. i tested from hot and cold....
demon87
F4i - Wanted
Feb 27, 2013 01:24 AM
Tomonfiya
Nov 14, 2009 09:14 PM
rozzzy
Jan 22, 2009 03:10 PM
maximus3
Oct 27, 2006 11:42 AM
