Need F4i Help
Need F4i Help
I have a 2004 Cbr F4I and I ran into a pickle. Here is the story, well I bought the bike from a repo auction and it was dumped hard. I brought the hog home and started to work on it right away. Not knowing much about CBR"s I was a bit lost. The first thing I noticed was a red light on the spedo right by the green neutral light. After figuring out the headlight needs to be completely plugged in for any chance of starting the bike I was happy with the results. The bike started right away and ran great. Well I rode it for about 3 weeks waiting for some parts to come. Last week I go to start the bike and that red I guess oil pressure light is on once again. A bit confused I play around with the headlight wires and no luck. I check the fuses and no luck. I changed the fuel pump fuse and now when I go to start the bike and hold the ignition button after 2 second the pump turns on the red F1 light appears and stops. The bike does not start. WHAT CAN IT BE!!! I'm so lost. Please help fellow members
Read this, then check the harness referenced (Left side, common melting place on these - they don't run a thick enough ground wire to headlights and tip sensor)
https://cbrforum.com/forum/showthrea...870#post615870
