need answer asap
Old Apr 28, 2006 | 09:57 PM
stuntn_r6's Avatar
Default need answer asap
well i just got a GPR stabalizer off of a guy and i have a question.....
On the stabalizer, is the dial supposed to turn and turn and never stop? Theres two clicks every full turn but it doesnt seem like it ever stops, is that right?
Old Apr 28, 2006 | 10:02 PM
city worker's Avatar
Default RE: need answers asap
such as ???........... you need to post the Q's before our knowledgable staff can help you
Old Apr 28, 2006 | 10:57 PM
stuntn_r6's Avatar
i fixed it right after i posted it...
Old Apr 29, 2006 | 01:57 PM
stuntn_r6's Avatar
well nevermind about that, kind of a stupid question i guess after playing with it...
but one other question, how strong is that nut that they provide...its nowhere close to being as strong as the stock one, and should i be afraid of it backing off?
Old Apr 30, 2006 | 02:26 AM
snobrdrdan's Avatar
I have no idea about what nut you're specifically talking about.....
But some Loc-Tite should help you out & hold it on there
Old Apr 30, 2006 | 06:33 AM
stuntn_r6's Avatar
im talkin about the big one that hold it onto the triple tree....
Old May 1, 2006 | 12:47 PM
Tahoe SC's Avatar
yea mang...that nut they provide is aluminum and all light and schiznit...but torque it to spec and also use some loctite if you afraid it back out...and worry free mang!
Old May 1, 2006 | 03:38 PM
stuntn_r6's Avatar
ok...last question about this....
when you set the peice of the stabalizer on there that bolts to the triple tree, it has a little bit of play back and forth...in other words, theres to tabs that come off of that peice to make it so you couldnt put it on backwards....are those two tabs supposed to be snug against the triple tree...because when i put it on theres maybe a 1/8" play back and forth between each tab hitting the triple tree....is it supposed to be like that?
did anyone understand that?
Old May 3, 2006 | 01:22 PM
stuntn_r6's Avatar
bump
Old May 3, 2006 | 09:35 PM
woodyracing's Avatar
if I understand your question correctly then look on the black part next to the tank, there are two pinch bolts with allen heads on them that you tighten to fit snug against the tripple so it doesn't move let me see if I can get a pic up of it
is that what your talking about though?
here is a pic of what I think your looking for:
http://img389.imageshack.us/img389/8269/pinch21bd.jpg
