MOTOR OIL TYPES
Old Aug 22, 2005 | 05:47 AM
xmunxjai648's Avatar
Default MOTOR OIL TYPES
I WANT TO KNOW IF THERE IS A CONVENTIONAL OIL OUT THERE THAT I CAN USE FOR MY BIKE, I'M RUNNING MOBIL 1 TRUCK & SUV 15W-50 RITE NOW AND IT'S CAUSING IT TO LOSE POWER DUE TO THE THICKNESS...I NEED A 10W-40 BASE, I DON'T WANT TO USE THE HONDA TYPES(TOO EXPENSIVE I THINK). ANY HELP??
Old Aug 22, 2005 | 10:54 AM
f4ilapper's Avatar
Default RE: MOTOR OIL TYPES
The honda GN4 is a petroleum base and is not too awful bad on price. I don't know if cheap is really were you want to go on this as it is also your transmission fluid. That my two cents.
Rob
Old Aug 22, 2005 | 11:50 AM
marcee77's Avatar
I thought Honda lube would be really expensive too but I called the shop yesterday to get a price and they told me 4 bucks a quart for the Honda Pro 10w40.
Old Aug 23, 2005 | 01:44 AM
sics15's Avatar
$3 bucks for the 10w40 and $6 for the synthetic at honda....personally Id run synthetic since your cracking high rpms...I have to agree with the not being cheap here...why you running 50 weight in your truck anyway?????
Old Aug 23, 2005 | 07:07 PM
i ran the 15w-50 cuz it's the closes to the require thickness for the trans but it lags in power...so i'm guess imma have to make a trip to honda for some oil
Old Sep 3, 2005 | 01:54 AM
yeah i just change the oil with Honda HP4 oil w/o moly...so my next ? is that, they told me that oil with moly makes the clutch slip..is that true?? i'm just wondering about it...cost the same with or without it
Old Sep 3, 2005 | 12:19 PM
kiggy74's Avatar
The Honda synthetic is a little pricy for oil ($6-7 per quart x 4 qts) but according to Honda you only have to change it once every 8000 miles. You'll never get that kind of life out of petro-based oils. Personally I would never go 8000 mis. before a change, but I can verify that synthetics last a lot longer. My car uses Castrol Synthetics OEM and my regularly scheduled oil changes occur once every 15,000 mis, even on a brand new engine! So on the bike, with the oil and filter, you'll spend $40 (at most) once every 6000-8000 mis. I think its worth an extra couple $ per quart.
Old Sep 3, 2005 | 06:19 PM
01600F4i's Avatar
Honda GN4 4 stroke oil, 4/quart, or buy the 4 quart bottle for like 13 or 14 bucks. I just did mine today, cost me 14 for oil and 11 for a honda filter. Don't use regular car oil.
Old Sep 4, 2005 | 07:11 AM
i use the HP4 synthetic w/o moly cost me $6 a quart...so that came out to be about $30
Old Sep 4, 2005 | 12:32 PM
Fox's Avatar
Fox
ORIGINAL: xmunxjai648
Did we warn you about the Caps Lock key yet? <joke>
I use Honda OEM fluids. Why not? They use the same fluids in their machines to benchmarket performance figures and specifications. Just use the correct weight and ves. and make sure it's a lube designed for motorcycles and more specifically one's for dry clutch systems. Watch out for "Engery Conserving" lubes. Best bet is to stay w/ Honda. Their GN4 lube is good, but I'm on the HP4 synthetic and the engine is much more happy w/ the synthetic lube!
