Micron high mount-use passenger pegs?
RE: Micron high mount-use passenger pegs?
02cbrf4i4u, could you post some pictures?
There's no way mine would've gone under the foot peg. it's just not designed that way.
Also all the instructions told me it would go over the foot peg and shouldcause no issue for the passenger.
If it went behind the foot peg, the spacer that mounts to the underside of the canister for support would not have a way to hook up.
The only issue I've found is I can no longer consider Side/Saddlebags and my right foot doesn't sit on my peg the same way as it is forced out and forward a little bit due to the new exhaust rerouting.
[IMG]local://upfiles/15290/E55BECFFBDE14AFFA4E87CEC4F6CDB3A.jpg[/IMG]
Nobble
titleAndStar(39,0,0,false,",")
oh ok so they do have some hardware to relocate the turn signal? that is good news lol...i thought i was gonna have to drop another 150ish on a undertrail before i could even think about installing the pipe...my hopw is restored! lol....thanks for the pics they help for visual.
-nate-
it still wouldn't hurt to look into some alternative Turn Signal option.
I've been wanting to get an integrated kit that would convert my brake light to LEDs and would integrate the turn signals into it as well.
no need to go with an undertail kit unless thats what you're wanting to do.
I did trim the rear fender a bit so it wasn't excessively long.
you will probably have to call Micron (micronexhaust.com) to ask about relocating the turn signals.
I'm not sure how that part will work on the 06 model as the rear fender is designed differently.
Nobble
-nate-
20HNDAF4i02
10-11-2007 01:50 AM
