Ive disconnected the PCIII and its still doing it. I guess my biggest issue is replacing something and it not fixing the problem. Fpr could be it. Even when it was warmed up last night it smelled like raw gas and it didnt throw a code.
ok a fueling system works with sensors it needs them all unless you have a stand alone. cars and bikes alike. you need a map sensor to make the bike run correctly. does any one know what the map sensor does?????. its controlls the fuel to the bike as well as the other sensors like the fpr the tps . the all work with one another . IT NEEDS THEM ALL . if its throwing a code for one 9 out of ten times its the sensor. very unlikly you have an electrical problem . GET A NEW MAP SENSOR..
Well I guess bikes going to sit til I can afford a new MAP sensor. Thanks everyone. Got any places in mind to find one not as expensive Ive seen 131 so far.
make sure all the lines are on there and no cracked or dry rotted ..
