A little concern - leak?
Old Nov 18, 2012 | 04:21 AM
lukewilly's Avatar
Unhappy A little concern - leak?
I've notice that I'm getting a couple of drips of thick oil coming from the gearbox area and im not sure if its a problem or just too much oil/lube on my can dripping after a ride.
i hope the pic isnt to bad
thanaks for your help Luke
(and yes the bike will be cleaned today :-) )
Old Nov 18, 2012 | 06:55 AM
MadHattr059's Avatar
Clean the area of concern and then monitor it. If it comes back, you'll
be more able to pin-point the location/cause. If it's a really slow leak,
you can elect to clean-up and top-off, instead of replacing seal/gasket,
(at least for a little while).
No need to panic, immediately.
Ern
Old Nov 18, 2012 | 09:57 AM
lukewilly's Avatar
ive just cleaned the bike thruout and it seems it was just dirt grim and excess oil but i will keep an eye on it thanks for the quick reply
Old Nov 18, 2012 | 10:57 AM
RudyGT's Avatar
you using chain wax? i've had buildup like that coming from my front sprocket before. and on the exhaust too, but different bike with a under chassis exhaust.
bottom line it gets everywhere if over applied and not cleaned regularly
Old Nov 19, 2012 | 12:32 AM
lukewilly's Avatar
yea i am using chain wax. (had it since i had a 125 :-| think i better invest in something a bit better, it wasn't cleaned very regularly but i do the body a few times a week and try do the chain sprocket oil ect every weekend so hopefully will stop, any recommendations for oil/lube?
Shiffts
Feb 28, 2012 04:29 PM
coldflood
Oct 9, 2011 11:05 PM
flyboy1011
Mar 16, 2009 10:05 AM
jerbear
Sep 15, 2007 02:29 AM
EPNF4i
Apr 6, 2007 04:26 AM
