LED Flasher relay on ebay?
Old Apr 4, 2009 | 04:49 AM
s1lVa's Avatar
Default LED Flasher relay on ebay?
Ive searched through eBay looking for a flasher relay.
Its the 2-pin relay right?
the prices are insane for such a small thing. ive come over 30-50$ for the thing some places.
is it really worth that much?
Old Apr 4, 2009 | 12:20 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Yes sir, you are correct
Just search "led relay" ~ here's one for $15.55. If you want the stock flash rate, then yes, they're worth it. Easy plug & play.
Old Apr 5, 2009 | 07:20 AM
Xuracing's Avatar
I have one, Great plug and play. Never gone back since!
Old Apr 6, 2009 | 10:21 AM
nor_cal_cbr's Avatar
Do you know if one relay corrects the front and rear or if you need two?
Old Apr 6, 2009 | 10:46 AM
Incognito's Avatar
The flasher relay is located under the upper (front) cowl, next to the bank angle sensor, between the headlight assembly. This controls all the turn signals. So to answer your question; you only need one
Old Apr 6, 2009 | 11:19 AM
Incognito's Avatar
Old Sep 1, 2009 | 09:00 PM
TurDz's Avatar
Don't mean to bump an old thread, but it is a perfect opportunity to ask this.
I bought an eBay 3-prong relay just like this one:
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Did I purchase the wrong type?
Thanks...
Old Sep 1, 2009 | 10:47 PM
Incognito's Avatar
If it comes with the connector pictured below, you're OK. If not, you may end up having to buy one (connector).
Old Sep 1, 2009 | 11:12 PM
sig556's Avatar
This one might work it looks like the one in the pic.
LED Relay
Old Sep 2, 2009 | 03:01 AM
Aken's Avatar
July 2008 ROTM
http://www.customled.com/products/fl...sher_relay.htm
