layed the bike down.... wont start
Old 04-12-2009, 08:09 PM
Aken's Avatar
July 2008 ROTM
Originally Posted by kpipalldaway
yes the headlights are hooked up! i wish it was that simple. how would i be able to tell if the stator was damaged. There appeared to be no physical damage to it when i removed it from the cover. and we briefly pressed the start button with the cover off just to make sure all the gears where turning with out resistance and they where. could the spark plugs have gotten flooded or something? Im sorry for my ignorance, I've spent most of my time under a hood, and im still new to the mechanics of a bike.
There's nothing majorly between a bike and car. A bike's motor is just far more compact.
Tell us something: With the bike off, make sure the ignition switch (the red one) is in the off position. Turn the key on, wait a couple seconds, then flip the ignition switch. Do you hear the fuel pump prime? If you don't, then that's something to investigate. Could be a blown fuse, or a wiring issue.
If the fuel pump primes and the bike just tries and tries to crank without getting anywhere, then (in my limited mechanical knowledge) I think it could be plugged injectors, or flooded spark plugs. Again, I THINK. I suck at mechanical stuff.
Old 04-12-2009, 09:26 PM
kpipalldaway's Avatar
there is a red light on where the gauges (and milages and whatnot) are, what does that mean, its just a solid red light.
Old 04-12-2009, 09:41 PM
Aken's Avatar
July 2008 ROTM
That's the Fuel Injection light. It will stay on until you start the bike, normal function. Now if it's flashing, then you have a problem.
Old 04-12-2009, 11:07 PM
skoobydoobie's Avatar
Did it go down on the left side. The kickstand switch might be f*ed up. Any damage to the clip-ons, maybe the kill switch? Could be a shorted ignition wire? Does the pump prime? If yes, then forget everthing you just read. It could be as simple as fouled plugs.
Old 04-12-2009, 11:27 PM
929Hooligan's Avatar
When I laid my bike down the tip over sensor killed the motor. Once it was back upright it would crack over but not start. Once I shut off the key, and also turned the kill switch off and back on it started back up. So I know even when the tip over sensor is tripped it will still crank just not fire.
Old 04-13-2009, 08:42 PM
Rotory2F4i's Avatar
did you check all the fuses? I know when my other F4i got layed down, it popped some/one fuses, long time ago and I dont remember what one popped.
americancbr929rr
08-02-2012 03:32 AM
itsgroll
05-28-2010 04:54 PM
bikerboy46032
03-10-2010 04:00 PM
tagger609
06-27-2008 02:09 PM
Thoryz450f
08-26-2006 03:16 AM
Quick Reply: layed the bike down.... wont start
