late night help please (battery ?)
THANK YOOOOU, I'll keep you updated because I knew something was wrong because my rear signal and tail lights ( consolidated LED signal mod) were acting up pretty bad then my battery died, it's a brand new battery too, i'm worried it's my regulator or rectifier allowing it to die
Here's a link to show you how to test your R/R. https://cbrforum.com/forum/f2-tech-93/regulator-rectifier-r-r-problem-solved-27739/. If it is your R/R it's best to replace it with one from a GSXR, the Honda ones pretty much are junk.
hmmm, maybe it was just a freak thing, if it happens again i'll deffinately do that. the only reason i'm not jumping on the idea is that my bike has hit me with like 7 things in the last month, care to listen????
worn tires
lost my right side bar end
my chain is in the red
my cam chain tensioner lifter is bad
my horn is not working
my front brake lever brake switch is dead
my battery gave me doo doo today
blew my left front forks oil seal (only thing i've fixed)
well that's it but DUDE, it all happened in like a month... IT'S LIKE FALLING APART!!!! I do ride it everyday but it only has 12,000 miles on it
worn tires
