lacking power on the low end
Old Jan 18, 2009 | 09:30 AM
KdubyaH's Avatar
June 2011 ROTM
Default lacking power on the low end
I dont know if its just the way they are or what. My bike seems to bog down a bit in the lower rpms. When I bought it, the bike already had a power commander installed. Could it be the way the bike is set up? A guy I work with was telling me to get a bigger sprocket. Can anyone recommend what size sprocket to make a bit more torque without losing a ton of top end
Old Jan 18, 2009 | 10:15 AM
rolandk's Avatar
Default RE: lacking power on the low end
Assuming your bike is running OK, try a smallerfront sprocket (-1) or a bigger rear sprocket (+2 or +3).
Old Jan 18, 2009 | 01:03 PM
F4iMane's Avatar
Alot of people have said that about their F4i. If you check the power commander set up and everything checks out alright then dont sweat it. I mean when your cruising around just keep the bike in the 5000 rpm range when you want power.
________
apartments for sale Pattaya
Old Jan 18, 2009 | 01:57 PM
Stephens's Avatar
I put a -1 in the front sprocket, and it made a huge difference for low end torque. Best money spent.
Old Jan 18, 2009 | 06:35 PM
Aken's Avatar
July 2008 ROTM
Get your Power Commander professionally tuned before doing anything.
Old Jan 18, 2009 | 08:45 PM
StrikeAnywhere's Avatar
ORIGINAL: Stephens
So stock rear and 1 down in the front made a noticeable difference? Stay with a 525 chain? Im sure this is in an old thread but I missed it.
Old Jan 18, 2009 | 09:57 PM
bwayers's Avatar
any time you change sprockets it will affect your acceleration and top end. one in a positive way, the other negative depending on how you alter your sprockets. if you want to keep your top end i would just leave the sprockets alone
you'd also need to run a speedohealer
also, on 99% of crotch rockets you will not need to dyno tune a power commander bc the available downloadable maps will be close enough to perfect you'd be wasting a lot more time than it'd be worth in the end.
just make sure the map selected for your power commander has the same general mods that your bike has. - i think there are 16 or so maps for the F4i
the 1% that could benefit from that would be bikes that have many more mods than the norm or have big bore kits/turbos etc
i'd stay with a 525 chain also bc the acceleration difference is generally barely noticeable but the durability just isn't there
Old Jan 19, 2009 | 05:29 PM
Stephens's Avatar
Go stock on the rear sprocket and -1 on the front. I also did a 520 conversion. You will see a difference on the gear change instead of the 520 conversion. It has so much more torque now, you can pop the front end up in 1st gear with the flick of your wrist.
Old Jan 19, 2009 | 05:39 PM
KdubyaH's Avatar
June 2011 ROTM
Thanks for all the info guys. Im going to just drop one in the front and see how that goes. I dont think im quite ready to pop wheelies at the flick of my wrist. lol. Im still a nooob
Old Jan 19, 2009 | 05:43 PM
Stephens's Avatar
When you change your sprockets, you need to change them both and put on a new chain. If you don't, it will wear one down vs the other. They have to have even wear on them. Also your speedometer is going to be off. Looks like your riding faster than you really are. Get a Speedohealer, this fixes the marginal error on your bike.
