Just a quick unanswered question about cct
Old Jan 22, 2014 | 05:25 PM
tqaa48's Avatar
Default Just a quick unanswered question about cct
Okay, Ive searched the the sticky everywhere and I never found an answer to the question: does the bike need to be at TDC or anything weird like that to change the CCT? Or is it as easy as just pulling te one ad putting the new on in?
Old Jan 22, 2014 | 08:10 PM
hoyt3's Avatar
New Member
no, no need for it to be at tdc.
Old Jan 22, 2014 | 09:15 PM
tqaa48's Avatar
Thanks brohan
Old Jan 27, 2014 | 06:59 AM
DonnyBrago's Avatar
Ideally, you'd pop the rocker cover to make sure that the chain doesn't skip a tooth and then check the timing before reassembly. Even more so when fitting a manual CCT so that you can set the tension correctly (turning it until the noise stops is not doing it correctly).
Of course most people don't do either and tend to get away with it.
viva_brasil
Jun 9, 2008 04:38 AM
oodayvidoo
Sep 23, 2007 02:42 AM
ChanCBR
Mar 22, 2007 12:18 AM
paseopower
Jul 21, 2006 01:41 AM
paseopower
Jul 13, 2006 03:01 PM
