Just Changed my CCT
Old Jun 11, 2009 | 12:14 PM
fourxchevy's Avatar
I decided to go with the ape manual cct cause my bike was on its second bad oem cct and the bike only had 9500 miles on it.
Old Jun 11, 2009 | 01:00 PM
beef66's Avatar
I made the bad decision to use a oem one. The rattling came back within 4000 miles. I want to get the ape just don't feel like going through the install again haha but will eventually
Old Jun 11, 2009 | 01:41 PM
florida f4i's Avatar
There is no competition in my book - manual is the way to go.
The OEM one fails because it's automatic, and the manual can be set, therefore it'll last as long as the parts are made to hold up until (which should be awhile).
Old Jun 20, 2009 | 08:59 AM
eljrc16's Avatar
can anybody post a link to know how to do this.
Old Jun 20, 2009 | 10:57 AM
snwbrdr435's Avatar
There is a whole write up on BARF on it. Search
Old Jun 20, 2009 | 06:20 PM
Tanknuts's Avatar
I read a post earlier about from someone who had 20,000+ miles on their bike and never replaced the CCT. They said at first the rattling got worse, but then later stopped. I'm gonna go on my stock one as long as I can bear it and see if it's true
Old Jun 20, 2009 | 09:16 PM
bwayers's Avatar
replacing mine took roughly 2 hours, but i also do this for a living
the reason most shops will quote 3 hours is they remove your valve cover to they can set the deflection in your chain to ensure proper tension
a few guys on here have tightened theirs by hand then cranked their bike and turned it until the rattling went away and tightened it down
which may work for some, but if they don't tighten it enough the chain slack can cause their cams to jump time and really screw up their motor
Old Jun 21, 2009 | 05:23 PM
You willing to take the chance and, worst case scenario, replace your entire motor if you are wrong?
It's really not that hard, guys.
Especially not worth the risk.
Old Jun 21, 2009 | 07:41 PM
NYKnick1015's Avatar
2 hours?? really... mines took 10 minutes... well mainly cuz its right next to the right side fairing door... and i can reach in and adjust it if needed
Old Jun 21, 2009 | 11:13 PM
littlehandegan's Avatar
Whats the average shop going to charge? Also whats the best manual one to use?
Thanks
