It's tire time...
It's tire time...
And I'm not entirely sure what I want to get. I'm looking at PP's, PP2ct's and Pilot road 2's.
I'd like to hear some of your thoughts on these tires! I'm kind of wanting something with good tread wear on the center (mostly straight michigan roads) that will grip pretty reliably in the twisties and of course value is a big consideration!
I'm open to other suggestions as well. Would like to hear your thoughts on some of these. Especially if you've ridden some or all of them!
Pilot pures. I just replaced a set, got 3 track days [fast B group pace, almost up to A group] plus 10,008 rear miles and 12,568 front miles. The rear was worn in the center, the front was worn half way between the center and the edge on both sides [right where the compound changes I think]. Last track day a couple weeks ago with the really really worn and heat hardened at this point tires was the first time I got the rear to break loose, still haven't lost the front. Find me a better all around value then that for $270 a set.
What kind of life is everyone else who runs the pures getting?
i have the bt016's and ill NEVER own anything else on any sportbike i own. theres no tire *in my opinion* that'll beat the triple compound these tires have. i've carved in the rain on them and they stick damn well, and i've put about 2k miles on them in the fashion of 2 up road trips, and STILL have no flat spot in the center. even did a gnarly rev limiter burnout and still no flat spot. i paid 200 for front and rear, and another 20 to have them both mounted. i believe cycle gear is running that special as well. i have pilot power's before and they didn't even compare to these things man.
