installing Frame protectors
Old Feb 23, 2008 | 10:37 AM
dumontf4i's Avatar
Default installing Frame protectors
i just bought some frame slides and saw that i need to make some fairing modifactions? what type do i need to make, is it a pain in the ***, i need to know what to do, thanks
Old Feb 23, 2008 | 10:52 AM
severetitan's Avatar
Default RE: installing Frame protectors
search.
Old Feb 23, 2008 | 10:55 AM
RatherHaveAnR6's Avatar
You will have to cut holes in the fairings, but make sure you get it right because the guy that had my bike before me messed it up. The holes are not centered on the slider, and they are oblonged because the slider wouldnt fit in them.
Use thesearch buttonto find a good method..... you're gonna get slammed with people telling you to search before you post. Just a heads up.
Old Feb 23, 2008 | 12:06 PM
voodoochyl's Avatar
Retired Moderator
Try these options:
playdo method
laser method
Old Feb 23, 2008 | 06:09 PM
TBFGhost's Avatar
I used the laser method on both my buddies RR and my 4i. We did his bike first and took about an hour or so due to setting up and being it was a first run I was being careful and double checking things.I thenI put them on my 4i in about25 min total. The lazer makes things SUPER EASY.....we used a 1 3/4 hole saw and you could not ask for a better fit, the sliders look like they are a part of the fairing with no gap, but they slide easy on and off.
Now if only people would start filling out more information when they register for this site, I could tell were about you lived and could offer for you to come over and I would do it for you for a small fee. Maybe something like $40 for both sides.....but i can't offer that because you and other people are lazy and won't fill that out.
Or I could come to you and do it for something like $60 plus the cost of gas.....but again I have no idea where you live.
Old Feb 23, 2008 | 10:19 PM
cjr5137's Avatar
i used the playdo method and it worked great. my vortex frame sliders fit perfect and have no gap. put the bolt in the hole then try to mount the faring as best as u can and drill the hole just take ur time and double check ur placment before u drill the hole u only have one try and use the 1 3/4" hole saw.
cbrfxsmithy_6_7
Jul 27, 2012 05:06 PM
AAA817
May 5, 2012 10:36 PM
Hudson
Dec 17, 2010 02:39 PM
tutman6
Mar 16, 2008 03:31 PM
QuinC
Riding Gear
Feb 18, 2006 01:11 AM
