idle knob help
Old Apr 7, 2008 | 09:00 AM
RZRS614's Avatar
Default idle **** help
i did a quick search already and came up without a answer. I tried ajusting my idle on the **** and it doesnt do anything. I tried to trace the line but could not see where it goes. So my question(s) are where does it lead to, do i have to take off any fairings to get to it, and what should i be looking for as the cause to it not working. Thanks much.
Old Apr 7, 2008 | 11:35 AM
ampfp's Avatar
Default RE: idle **** help
afaik the idle **** adjusts the zero position of the butterfly valves through tension in a cable... in which case the cable would go to the throttle body from the left (to under the tank from under the left fairing).
That's odd though. did you try turning it multiple turns one way or the other? Maybe it was too loose/tight to begin with.
sikuwolf
F2 Tech
Feb 23, 2011 09:25 AM
prowheelie92
Jan 26, 2010 06:50 PM
Memphistn3000
Dec 8, 2008 08:02 PM
islandinatoilet
May 25, 2008 09:52 PM
racerrick
Nov 3, 2007 07:20 AM
