Idle Control Cable
Old Jul 17, 2021 | 08:42 AM
EzzyCakes's Avatar
Default Idle Control Cable
I was messing with the idle control cable on my 2004 honda cbr600f4i because the idle was too low and I accidently backed the whole screw out. During this process I lost the spring that was on the end of the cable and cant find a replacement spring. The bikes is basically undrivable now because the revs keep bouncing around unpredictably. I just wondered if i could insert the idle control cable back without the spring or would that cause additional problems.
Old Jul 17, 2021 | 10:24 AM
In my experience, on my model you do need the spring. When I did what you are describing it took me forever to find it but it was tucked way underneath the starter.
Old Jul 17, 2021 | 11:35 AM
EzzyCakes's Avatar
Do you think any spring from a hardware store would work if it fits?
Old Jul 17, 2021 | 01:14 PM
EzzyCakes's Avatar
Also, to install the screw back indo I just have to remove the gas tank and the air box?
Old Jul 17, 2021 | 02:19 PM
If you can find one that fits it should work as long as it has the right amount of “springiness”.
I seem to remember maybe 4 or so years ago someone posting about an alternative spring they found.
im not 100% sure on your model but you shouldn’t need to remove much more than that.
Old Jul 20, 2021 | 01:06 PM
EzzyCakes's Avatar
I got everything installed and the bikes runs good but it idles at around 3.5. Adjusting the cable doesn't seem to change it at all
Old Jul 20, 2021 | 02:11 PM
Did you find a spring?
Old Jul 20, 2021 | 04:21 PM
EzzyCakes's Avatar
yeah, but it was a little longer than the oem spring but not does not take as much force to compress.
Old Jul 21, 2021 | 06:25 PM
Well that stinks. What are your plans?
Old Jul 22, 2021 | 02:49 PM
EzzyCakes's Avatar
yeah I little, im just gonna keep it as it for right now but be on the lookout if I can find a spring of the right specifications. If not, ill probably just ended up buying a new cable that comes with everything since its only around 20 bucks
