idle cable fell off
Old Oct 20, 2013 | 03:35 PM
tamahda's Avatar
Default idle cable fell off *solved*
After fixing a map sensor issue I noticed my idle adjust **** made no effect to my idle. While twisting I noticed no tension what so ever. After fiddling with it the entire assembly fell out. If anyone knows the location to where the cable originates I would appreciate any help thanks.
Old Oct 20, 2013 | 05:07 PM
Diesel7926's Avatar
this link should help you see where it belongs look at #7
2002 Honda CBR600F4 A THROTTLE BODY | Babbitts Honda Parts House
Old Oct 20, 2013 | 11:18 PM
tamahda's Avatar
thanks a ton! ill see if i can return it with that diagram much appreciated
Old Oct 21, 2013 | 06:39 AM
Diesel7926's Avatar
no problem, let us know how you make out!
Old Oct 24, 2013 | 10:56 AM
tamahda's Avatar
Is it possible to reintroduce the idle adjustment cable to its original home without having to to remove the gastank/airbox? I have a good idea as to what to look for and where to look however as you all know, it's pretty tight in there.
Old Oct 24, 2013 | 10:57 AM
tamahda's Avatar
As well after I return it is there going to be any other adjustments needed?
Old Oct 25, 2013 | 11:08 AM
tamahda's Avatar
Anybody here have this problem before?
Old Oct 25, 2013 | 01:10 PM
Diesel7926's Avatar
As long as the bike is idling well right now with the cable off I would just adjust it to the throttle plate and then stop, You are likely going to have flip up the tank and take the airbox off to be able to get at it. Otherwise you might be in for a fight to try and get it in
Old Oct 25, 2013 | 02:17 PM
tamahda's Avatar
Ok great! Will keep you posted on my progress
Old Oct 26, 2013 | 12:20 PM
tamahda's Avatar
once again the cbrforum (props to diesel7926) has assisted me with solving yet another issue!
the following video is both map sensor and idle screw set issues solved with christine saying "Thanks!"
I managed to return the screw set back by using a pair wire grabber/pullers and persistence.
jdschmidt
Feb 14, 2021 02:38 PM
voyager
Aug 22, 2012 09:21 AM
Knewz
Mar 30, 2009 03:38 PM
On Sale
Aug 15, 2007 02:54 AM
pointman
Sep 11, 2006 01:53 PM
