I think I need a new chain
RE: I think I need a new chain
I am in a current situation likethe O.P. I have an 03 F4i that now has 11,800 miles (I originally bought the bike with 8.2k). Now I checked the chain and there's a some amount of rust on it...should I go and replaced it and since I am doing that should Ireplace the sprockets?
Also, how long does a chain normally last? Does that depend on how well it's taken care of? Since I bought it used and unknown of how the prior owner took care, would it be wise to spend the cash and get this done?
Thank you
Thank you
chain usually last from 8 to 16K or so, depending on chain, how much you ride, how you ride and how well it is maintained.
rust on the side plates doesn't mean the chain is no longer good. it has more to do with if the links are kinking and if the chain is stretching. when a chain goes bad, you'll see tight spots here and there and and/or you'll be adjusting chain tension everytime you ride.
now if your chain has little rust spots on the plates here and there, but all else is ok, then no need to replace. just clean and lube the **** out of it. if it's way rusty and looks like it'll give you lockjaw or will snap, then by all means replace it...WITH DID only...
again, i stress that unless you need the weight savings for track/racing, then a 525 is best. keep the same gearing and changing from 525 to 520 won't give you any noticeable increase in speed, etc...but swapping gearing will.
t
t
ORIGINAL: Tahoe SC
Here are a few kits a quick google brought up. Make sure you payattention to what color thechain is, I personallydo not like gold chains on most bikes...
+1 Front Sprocket
http://www.kneedraggers.com/details/...i--615114.html
Stock Gearing but 520 chain
http://www.starcycle-usa.com/servlet/Detail?no=6247
Stock Gearing but 520 chain (ebay)
http://cgi.ebay.com/ebaymotors/520-V...QQcmdZViewItem
Choose whatever gearing you want and 520 Chain (RK)
http://stores.sportbiketrackgear.com/Detail.bok?no=1061
Choose whatever gearing you want and 520 Chain (DID)
http://stores.sportbiketrackgear.com/Detail.bok?no=1060
ORIGINAL: TBFGhost
WHAT?!!! I have NEVER EVER had a problem or noticed a difference between RK, EK, Reginaand DID.
ORIGINAL: Tahoe SC
just calling them as i see them. i've heard of issues with RK, EK, etc, but not DID...i've experienced issues with RK, EK, but never DID. IDK about regina.
you know...when i picked up my last chain and there was this dude in front who wanted RK, and bought RK...i asked my supplier why the heck he sold him that POS...he said "i know i know, but he insisted he wanted RK so i gave it to him"...i said "but you and i know that DID is the way to go...you should only be selling DIDs"...he said "hey, i would if i could, but that means i'd lose business with all the nut jobs who don't want DID"...then i asked..."so if someonen came in and said they wanted the best chain (not necessarily most bling or best ever but just quality for all levels of chains) what would you sell him"...he said.....blah blah blah...
