I need help.
Old 04-04-2011, 01:06 AM
XgunnerXTC's Avatar
Question I need help.
I need some help and advice. I need to either fix the digital Tac and Speedometer, or make them analog.. How hard is it to do either or and about how much?
Old 04-04-2011, 02:17 AM
Aken's Avatar
July 2008 ROTM
Just fix it. For analog you need to hook up a mechanical sensor, run a cable, etc etc. Diagnose what's wrong and see what needs replacing, and fix it. Worst case scenario, you need to get a new set of gauges, which can be expensive depending on condition and who is selling it.
Old 04-04-2011, 10:09 AM
Xander F4i's Avatar
have you checked the four plugs on the harnesses? it seems that they like to come unclicked from the back of the cluster.
Old 04-04-2011, 10:11 AM
kazspeed's Avatar
What exactly is wrong with it?
Old 04-05-2011, 02:12 PM
XgunnerXTC's Avatar
It doesn't come on. The clock Kinda works but its wrong.. But I know for a fact the Speedodmeter does Not work.
Old 04-06-2011, 01:43 AM
Aken's Avatar
July 2008 ROTM
Sounds like a simple electrical issue. Check all your harness plugs and fuses.
Old 04-06-2011, 04:35 AM
nickp123's Avatar
Check the connection of those two plugs that go into the back of it.
*Some (dis)assembly required.
